  How to fix side mirror?
How to fix side mirror? by RWB 87 GT
Started on: 06-27-2020 11:18 AM
Replies: 2 (159 views)
Last post by: RWB 87 GT on 06-28-2020 09:35 AM
RWB 87 GT
Report this Post06-27-2020 11:18 AM Click Here to See the Profile for RWB 87 GTSend a Private Message to RWB 87 GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 Gt has a loose passenger side mirror glass that rattles. Is this easily removed and re-secured? I have done multiple searches with no results shown. TIA DL
Report this Post06-27-2020 08:20 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glass is glued to adjustable part then that screwed or etc to shell.
Tip glass up/down/sideways to see the 3 mounting points.
remove whole thing to look at back or fix whatever.
Shell is bolted to door w/ nuts inside of door.
RWB 87 GT
Report this Post06-28-2020 09:35 AM Click Here to See the Profile for RWB 87 GTSend a Private Message to RWB 87 GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Ogre for the reply, I found 2 of the screws were loose. Added small washers under the heads as the holes are corroded. DL
