  Fiero brake upgrade question
Fiero brake upgrade question by DefenderMG23
Started on: 06-25-2020 03:16 AM
Replies: 6 (716 views)
Last post by: DimeMachine on 07-13-2020 12:26 AM
DefenderMG23
Report this Post06-25-2020 03:16 AM Click Here to See the Profile for DefenderMG23Send a Private Message to DefenderMG23Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has anybody successfully done a brake upgrade using a booster other than a S-10’s? Have heard it’s slightly better but still has similar pedal feel. Looking for softer feel for spouse that’s comparable to an early 2000’s vehicle.
jjd2296
Report this Post06-25-2020 07:26 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Don’t know where you got that info from. The s10 booster reduces the pedal pressure by 50% ! Definitely makes it feel like a 2000s car. And it’s the same whether you just swap the booster or do a brake upgrade as well.
Report this Post06-25-2020 02:13 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be your Booster is "bad," have vac problems or maybe both.
Examples:
84-86 Fiero and other cars have a vac filter in engine bay like to plug. OE is Metal Can on firewall.
All have a vac check valve that leaks/plug internally after 20-30 years. 84-86 has different valve then 87+ because 87+ uses bigger vac line.
Booster could have 1 of 2 diaphragms fail causing harder pedal.
Could be you have other brake problems causing hard pedal.
Example: MC w/ iffy QT valve can cause hard pedal.
See my Cave, Brake Service, Quick Take-up notes and rest of section.
[This message has been edited by theogre (edited 06-25-2020).]
darbysan
Report this Post06-25-2020 04:00 PM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I did the upgrade, I used the kit from Rodney's store, and the recomended booster I got from Summit racing. I prefer this setup as you might need a replacement booster in the future ( I did), and it was easy to purchase a replacement.
https://www.summitracing.co.../chevrolet/year/1993
http://rodneydickman.com/pr....php?products_id=350
'87 GT , '00 3800 Series II SC, 4t65e, Vue Power Steering. (SOLD)
Lou6t4gto
Report this Post06-26-2020 04:50 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
the GOOD S10 booster on a "properly working" stock fiero brake system, with very little pressure it could almost throw you into the dash. if it doesn't, something is wrong.
branger
Report this Post07-12-2020 11:15 PM Click Here to See the Profile for brangerSend a Private Message to brangerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did the bigger booster from summit racing, needed to also buy the little adapter extension. You also need the bracket from the original booster. Drill out the pop riveted bracket on the old and bolt on the new. There’s a guy who posted it on YouTube, super helpful. I found this mod gave me better brake feel. Now looking at the grand am caliper upgrade. More to come.
DimeMachine
Report this Post07-13-2020 12:26 AM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love the S-10 booster upgrade. In my car is was a material difference about 7 years ago. I would give it 2 thumbs up. But also do check the items Ogre mentioned to make sure they are functioning properly as these are 30+ years old now.
