  120 speedo swap
120 speedo swap by yellow peril
Started on: 06-24-2020 04:11 PM
Replies: 3 (169 views)
Last post by: jscott1 on 07-02-2020 12:06 AM
yellow peril
Report this Post06-24-2020 04:11 PM Click Here to See the Profile for yellow perilSend a Private Message to yellow perilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 1988 4cyl notchie. I've installed the center console gauges( batt and oil pressure) those were easy plug in and go.
can i just remove the 85 mph speedo cluster and just plug in the 120 cluster or is there modifications required?
Total ratings: 207
Report this Post06-24-2020 11:01 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plug and play
Are your tach and fuel/tach gages backlit?
yellow peril
Report this Post06-29-2020 05:14 PM Click Here to See the Profile for yellow perilSend a Private Message to yellow perilEdit/Delete MessageReply w/QuoteDirect Link to This Post
sorry took so long, computer issues. yes they are back lit
jscott1
Total ratings: 415
Report this Post07-02-2020 12:06 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can't run two oil pressure gauges in parallel, (the resistance is too low and inaccurate) so until you get that 120 tach in there you need to cut the wire to the build in oil pressure gauge.
[This message has been edited by jscott1 (edited 07-02-2020).]
