  Gauge replacement in a backlit cluster
Gauge replacement in a backlit cluster by imacflier
Started on: 06-22-2020 12:33 PM
Replies: 3 (125 views)
Last post by: rbell2915 on 06-23-2020 09:21 PM
imacflier
Report this Post06-22-2020 12:33 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good Afternoon, All
Well this seems to be Larry asks silly questions day....but: does a standard 2 1/6" gauge fit into the backlit instrument cluster?
I would consider a digital fuel gauge if it just a matter of swapping the gauge....well and interfacing, of course.
Is there any size gauge that will work?
Anyone try it?
TIA,
Larry
rbell2915
Report this Post06-23-2020 04:02 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you planning on swapping the temp gauge as well? They are both on the same gauge. You can't do only one.
imacflier
Report this Post06-23-2020 05:41 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, I really hand not considered changing another gauge....I am quite fond of the existing gauges.
Why could I not change one and not the other?
Larry
rbell2915
Report this Post06-23-2020 09:21 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Larry
I was under the impression that you were trying to swap only the fuel gauge to a digital one. Which wouldn't be possible since the fuel gauge is combined with the temp gauge. You would have to do both at the same time. Not one or the other.
