  Hunting Gremlins and Misfires in my 86 Fiero GT
Hunting Gremlins and Misfires in my 86 Fiero GT by bootdsc
Started on: 06-09-2020 05:47 AM
Replies: 19 (589 views)
Last post by: bootdsc on 06-21-2020 01:49 AM
bootdsc
Report this Post06-09-2020 05:47 AM Click Here to See the Profile for bootdscSend a Private Message to bootdscEdit/Delete MessageReply w/QuoteDirect Link to This Post
*edit* Solved, the main problem was a failing pulsator, replaced with fuel submersible 5/16th hose and high pressure clamps.
I've learned a lot about this 86 fiero gt (automatic) in the last week of wrenching on her but these gremlins have me feeling like a noob.
The car was running on default/limp when purchased which i was unaware of or i would have drove the price down another grand, i have started to replace everything for the sake of having a nice tuned up reliable daily driver but also because of the chity chity bang bang spudder misfire it developed.
May be important to mention it was only 75-80 when i bought the car and has been 100-110 for a few days before the problems started.
First up replaced the O2 sensor that had broke in half and blown out the side of the manifold. Also while in the engine bay i reconnected the vapor canister. This took care of the code 13 and 44.
Few days later the temp gauge was a bit jumpy and when i parked to pickup groceries it overheated and spewed out coolant, there was a great deal of air in the system, i refiled it the correct way and no more heat issues and no air bubbling into the reserve tank.
Car ran fine for the next couple of days.
Now on another real hot day the engines running good for about 30 minutes until it starts misfiring, sputtering, idle jumping. My first guess was something overheating again so i let it cool down than limped it home, it ran ok but didn't have much power until getting up to speed and over 2500rpm it ran fine.
Started looking into what might be the cause and down the rabbit hole we go.
Everything i have done so far has not just been in the hopes of fixing this misfire but also for general maintenance and tune up. These were all done one at a time with some driving in between and ecm resets to see if there was any improvement.
I have replaced all of the soft vacuum lines and the hard lines look to be in good shape but next up ill do the spray test, i haven't bothered yet since the motor would just stall when turned on and left in park so its hard to check for rpm jumping when it wouldn't even stay on. i decided to move on with replacing stuff until it ran a little better.
Cleaned and reinstalled engine to body ground strap connections, installed second ground strap. This fixed the flickering and dim dashboard lights but had no other noticeable affect.
Replaced the air intake filter. I've never seen such an old and filthy filter on a car.
Spark plugs showed normal wear and no abnormal corrosion or build up but had signs of arcing over the ceramic.
Replaced with stock ac delco.
New spark plug wires from Napa, premium lifetime warranty set. idk who makes them.
New ac delco ignition coil.
Remanufactured distributor from napa, came with rotor, cap and icm. The original was rusted and corroded plus the coil pickup was falling apart so bad idk how the car even ran.
Did the timing the best i could, its like 10.25-10.50. This was difficult with the unstable idle but the engine did settle down after some time.
I'll revisit this as i think it might be making it run lean?
Replaced the starter motor, the repeated cranking while working on the car(mostly from doing the timing) smoked the old one pretty good.
It had that wonderful burnt coil coating smell and was starting to load the battery real hard with every start which was taking longer and longer, i even had to start jumping the battery.
Replaced PCV, old one still seems to be in working order but it had a lot of gunk built up.
Replaced the air charge temp sensor. I don't know if the old one was bad but it was covered in a thick layer of rust.
Replaced IAC and here's where i actually thought i had figured out the cause of my misery.
I unplugged the old IAC and like magic there was no more weak idle, no misfire and the engine wasn't dying while stopped in drive. RPM stayed at 1300 while stopped and would shoot up to 2500 while in park, if i turned the AC on while parked it would settle around 1500.
The car had all its power back and everything seemed great. the next day it was back to the misfire, spudder, idle dropping and not being able to accelerate or even get the rpm's over 3k.
Replaced the IAC (no ecm reset) and after a few minutes of driving got a engine light, stopped and checked it was 35 and 44. Reset the ecm and started trying to drive the car around to let it relearn everything but it was back to having little power and wanting to dye with low rpm every time i slowed down.
Eventually it started running decent so i took it for a long drive and it seemed like the ecm relearned its stuff and was driving pretty good.
Took it up on the freeway and within a few minutes loss nearly all power and had to stop. I unplugged the new IAC and like magic again there was almost no studder, only 1 misfire and no low idle problem.
This brings me to right now where i'm running out of ideas. I don't have a known good ecm to try out nor do i want to buy one and wait 10 days for delivery. The MAP sensor may need replacing but i wont bother until after i can properly test the vacuum lines and today i found my vacuum pump gauge is dead, probably a bad internal seal.
One other thing that idk if its useful info but besides running on limp when i bought it the fuel pump relay was bad and the car was driving with the oil pressure switch engaging the pump. I replaced the relay and now the pump turns on like it should.
What i can't figure is why it'll run fine all day than suddenly start the misfires one day but another it'll be right when it starts up, its all very random. It does seem like i've been dealing with multiple problems. Grounding is fixed, 02 sensor fixed, ICM grounding bolt fixed, weak spark fixed, fuel pump relay fixed.
In between this intermittent problem the motor runs great, the cars so ****ing fast and fun to drive, i can quickly accelerate up a steep incline without issue. I've got the rear sway bar kit sitting in the living room waiting to be installed.
This is one sweet ride and i've just got to figure out this last problem it has. The fiero forum isn't terribly useful since most posts are over 10 years old and few people ever bother to post the solution or maybe they just gave up? Idk but if any of you have bothered to read this whole thing and have a solution that fixes my engine ill buy you a six pack.
I'll be reposting this in all the fiero forums and maybe some other reddit subs so maybe it'll be seen by someone who knows.
[This message has been edited by bootdsc (edited 06-21-2020).]
Report this Post06-09-2020 08:30 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You may want to break that post up into a few paragraphs that more of us can tackle at our own pace. Its easy to get lost in all that text..
Report this Post06-09-2020 10:51 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the same misfire problem. Sometimes it does. Sometimes it doesn't. Watching
Report this Post06-09-2020 11:14 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
pull tack filter when trying to fix problem(s) w/ HEI.
See my Cave, HE Ignition and Ground "Myth" notes
Report this Post06-09-2020 01:13 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I couldn't get those two links to open. Computer just clocked on both.
Report this Post06-09-2020 02:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agree 100%. No disrespect to the OP, but I don't even bother to try and read something that long with no paragraphs to facilitate easier reading. Just go back and edit your post by using the Enter key a bunch of times!
I have the same problem when trying to access the Ogre's Cave. First noticed it a couple of days ago.
[This message has been edited by Patrick (edited 06-09-2020).]
Notorio
Report this Post06-13-2020 12:59 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try again today (13th). The Cave links worked for me this morning.
Notorio
Report this Post06-13-2020 01:05 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Notorio
Member since Oct 2003
Originally posted by bootdsc:
In between this intermittent problem the motor runs great, the cars so ****ing fast and fun to drive, i can quickly accelerate up a steep incline without issue ...
It's safe to say that even the v6 version is rarely described as 'fast'. Something to keep in mind is that a previous owner may have done some upgrades that you are not aware of, not that that helps in the present circumstances. Now that the links are working check Ogre's Cave. My thought was perhaps the EGR is misbehaving.
Report this Post06-13-2020 05:01 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The various links to Ogre's Cave now seem to eventually work, but they each take about ten seconds to open... which in this day and age of instant internet access, is an eternity!
bootdsc
Report this Post06-15-2020 05:16 AM Click Here to See the Profile for bootdscSend a Private Message to bootdscEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blame the formatting on copy paste, fixed it well enough.
I'll have a look at that ground reference wire thanks. The cave has already been a big help in figuring out everything.
Okay so there has been some progress made.
EGR tube was snapped clean in two and certainly the main problem I've been having. Made a temporary fix using a combination of jb weld exhaust pipe repair kits. I'll get a new one from fierostore.
The battery I bought from autozone wasn't rated for high enough cranking amps, my fault for not checking and going off what their system recommended. Swapped it out and I'm able to start it reliably on the second try.
There's still some idle hunting and misfires but I'm pretty sure it's just another small vacuum leak from a rubber block that connects 4 vacuum lines, it's right by the thermostat housing. I haven't found a suitable replacement so I'm just going to build one.
Tomorrow I'll replace the map and water temp sensor, that'll only leave the oil pressure sensor to replace later down the road.
There's one last thing I haven't found a answer to, there's 1 random black wire that's broken off of something in the same area of the map sensor and I just can't find where it goes. I'll post up a picture later, maybe one of you fine sirs will know.
The previous owner kept good records and they did more maintenance than I'd expect from anyone but the car was garaged for 2 years and it hasn't had anything replaced in the last 8 years, don't know how much of that time it spent on the road.
She seems to be in good shape overall, besides the not so fun part of fixing random **** I'm getting ready to build some 2" fender flair's in the rear and 1" in the front, I hate calling it a widebody mod. It's going to be painted hugger orange and I'll leave the silver trim stock.
Any good reason to not use wheel spacers with the Fiero? I really like the stock wheels and I don't want to replace them just to get the offset I need
[This message has been edited by bootdsc (edited 06-15-2020).]
Cliff Pennock
Administrator
Total ratings: 696
Report this Post06-15-2020 03:58 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
TL;DR 😉
Did you replace the ignition module? That would have been the first thing I'd replace when it misfires.
Report this Post06-15-2020 06:35 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found the problem with my misfire. It was caused by the leaves and debris collected around the front bank of plugs. Took an air blow gun with a long extended tip and blew all the debris out and the problem went away. Two tanks of fuel through it and not a single misfire.
Notorio
Report this Post06-16-2020 11:39 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
So that means the debris was causing the plugs to short to ground?
Report this Post06-17-2020 12:30 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are some members here who think using wheel spacers/adapters rates right up there with cutting a coil off a spring... they don't feel it's right. IMO, it depends to what degree in both situations it's being done.
I've run these 1" hubcentric spacers on the back (just the back) of my Fiero(s) for the last 14 years with absolutely no issues They bring my Sunfire wheels (with the wrong offset) out to the edge of the fenders (instead of being tucked in too far).
Keep in mind that using spacers to push wheels out beyond where the factory intended the wheels to sit will put greater stress on the wheel bearings.
[This message has been edited by Patrick (edited 06-17-2020).]
Report this Post06-17-2020 08:55 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes...with a little moisture added.
Report this Post06-17-2020 09:56 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The plug boots also needed a reapplication of dielectric grease. I apply a liberal bead around the opening of the boot so it's distributed along the plug ceramic as the boot is installed. Also helps prevent the boot from sticking to the plug.
bootdsc
Report this Post06-18-2020 05:11 PM Click Here to See the Profile for bootdscSend a Private Message to bootdscEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the suggestions. Since last time here's what I've done.
Reinstalled the spark plugs and cleaned a bit of oil and gunk from around the area but there wasn't much. My Fiero was kept in a garage. Plug boots got a good sized bead of dialectric.
Cleaned the ground that's below the ECM, it was slightly corroded.
Should there be more than 1 wire at that ground point?
Cleaned the positive distribution block by the battery. Everything was very corroded.
Checked for ECM ground on the engine block, it's still there and intact connected by two bolts but I haven't removed them to clean it up. idk how to get back there.
Replaced the fuel pump and strainer. Tank looked perfectly clean but idk what might be under the plastic insert. I saw no signs of rust or gunk.
I have 3 ICM's, 2 are new 1 is old and there's no change when swapping between them.
Installed a new MAP sensor.
Replaced all remaining vacuum lines and boots that leaked.
Reset the throttle body idle set screw. The previous owner drilled out the the plug and fcked with it.
My current thought is I'm intermittently losing vacuum which stops the fuel pressure regulator from working so when I try to accelerate the injectors are starved.
For the last few days I've had to use starting fluid to start her up if it's sat more than like 4 hours between restarting.
This morning I drove around the block (idle speed mostly) until I got a check engine light, it was code 35 and 44. The incorrect idle isn't important now but running lean sure is, this is what I've been fighting with for 2 weeks.
Tonights project will be installing a new fuel pressure regulator and replace the vacuum line boot. Maybe replace the water temp sensor, the thermostat and do a cold start injector delete since I live in the hottest part of the USA.
Engine shot just cause and yes I know the IAC is disconnected in the pic. https://imgur.com/a/AHRBvMI
[This message has been edited by bootdsc (edited 06-19-2020).]
bootdsc
Report this Post06-18-2020 05:15 PM Click Here to See the Profile for bootdscSend a Private Message to bootdscEdit/Delete MessageReply w/QuoteDirect Link to This Post
bootdsc
Member since May 2020
I hadn't thought about added stress on the bearings but I did figure I'd need to adjust the camber. I just like the stock wheels so much I can't part with them just for a wider stance. 1" out front and back and I wouldn't even need to add fender flares, do you have a source for the spacers you used?
Report this Post06-18-2020 05:38 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
eBay, where else?
Just make sure the spacers are indeed hubcentric.
bootdsc
Report this Post06-21-2020 01:49 AM Click Here to See the Profile for bootdscSend a Private Message to bootdscEdit/Delete MessageReply w/QuoteDirect Link to This Post
For anyone who finds this thread ill summarize, there were multiple problems which made it difficult to find the one causing the intermittent lean condition which in tern caused misfires.
Ended up being a pulsator with a non visible crack that prevented the fuel from reaching any higher than 12psi when it should of been 36-45psi. Solution is to replace the pulsator with fuel submersion rated 5/16th hose and use two fuel line hose clamps to hold it in place.
