  Steering is very tight on my 87 2M4
Steering is very tight on my 87 2M4 by Chris Eddy
Started on: 05-31-2020 11:02 PM
Replies: 5 (253 views)
Last post by: Chris Eddy on 07-27-2020 08:20 PM
Chris Eddy
Report this Post05-31-2020 11:02 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
For some reason, my steering is very tight.
I can turn the wheel with great effort, and then car will continue in that direction, not return..
You can feel the wheel eek eek in discrete motions when turning, not smoothly.
I did have a loose steering column, but fixed that a few years ago.. no issue at that time.
Thoughts?
Mike in Sydney
Report this Post05-31-2020 11:20 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the problem with the suspension unloaded, i.e.: both wheels off the ground at the same time?
Mike in Sydney
Report this Post06-01-2020 08:10 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That sounds like a bad front ball joint.
Do not drive the car until you find the problem.
Chris Eddy
Report this Post07-12-2020 08:44 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So it took me a while to work my way into it, but here is what I have..
Popped off the tie rod ends, no change.
Unbolted the rack.. when steering, still tight but rack does not twist.. indicating that..
It is the column.
A few years ago, I did the column tighten dance, taking the whole shebang apart to tighten the bolts.
But now it is very stiff and tight.
Are there lubrication points on this somewhere? Is it all buried in there where the bolts are? Are there replaceable plastic bearings?
Any "save me time" appreciated..
Report this Post07-12-2020 11:43 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The column has a few part that could bind...
1 is the infamous 4 bolt and metal screws into can work loose again.
lock pin spring can fail or crap got in binding the lock plate.
is likely Not bearings. Only 1 BB type at top.
have to pull column or rack to separate them.
Column and lower should not move in/out. If does then plastic part of crush zones failed and needs replace of the whole part.
Chris Eddy
Report this Post07-27-2020 08:20 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
One step forward, two steps back..
I pulled the rack out of the car.. and alas, the column spins like a top on Jolt.
The rack is bad.. un-rebuildable bad.
The one end had a bad inner that would not easily pivot..
But the worst is that the right end, which has a long casting part over the inner, was plain busted off, and just rattling around in there.
And I am pretty sure that the last person in there looking at it left it just the way it was.
And then of course the whole rack, which had some grease, but not enough, was very tight. Could be the shaft going into the rack.
And there is a broken piece on one of the mounts where the rubber pads go.
All in all, a loosing proposition, I ordered another rack. It is the LAST thing that I want to jiffy fix.
