  Volts and Idle
Volts and Idle by 72and86
Started on: 05-31-2020 12:41 AM
Replies: 4 (437 views)
Last post by: 72and86 on 05-31-2020 02:33 PM
72and86
Report this Post05-31-2020 12:41 AM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just purchased a project 86 SE V6. It was not running. Got it running with a new coil and distributor rebuild, but determined it needed a water pump which is installed. Now the idle is all erratic and the volt idol-light is flashing on and off systematically every 3 seconds. (Volts is fluctuating between 10 and 11 volts, sometimes less.) Previously before the water pump was installed it had no such issue. Whats going on? Any ideas? Wiggling alternator connector reveals no connection issue.
dremu
Report this Post05-31-2020 01:11 AM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
Belt tension is first thing that comes to mind. Belt slippage on the alternator leads to lack of output.
-- A
Total ratings: 458
Report this Post05-31-2020 02:29 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
All grounds are in place?
Report this Post05-31-2020 09:02 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just above the water pump is the MAP sensor and a lot of vacuum lines. Check to see if any were damaged during the water pump repair.
[This message has been edited by Gall757 (edited 05-31-2020).]
72and86
Report this Post05-31-2020 02:33 PM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
-- A
It was the belt! bingo.
