I stupitly tryed to take off my deck lid at the firewall and now , after I have it back together it does not stay up , what adjustment do I have to make and how do I do it. Any help wil be apprecated. It is cold ,raining hard and very early to be messing with this. Sorry about my spelling!
No I just started to try to take the deck lid off at the firewall,after I diecded that was the wrong thing to to do I put it it back, Now it do's not want to stay open.
If you did not take the pin's out that hold the spring's (this pin can be moved from hole to hole to add or subtract spring tension) then you inadvertantly flipped one of the spring links over. This will nulify one of the springs, so only one of the springs is holding up the lid. If you took out the pin's you may have put them back in the wrong hole. If one or both links were flipped over you need to take off the deck lid to readjust the link/links.
[This message has been edited by Rickady88GT (edited 11-19-2003).]
I started on the right side. I first removed the plastic triangle piece circled in GREEN. I then attached a hook on the torsion bar where the BLUE arrow is. Using a ratcheting tie strap I pulled the torsion bar off of the pin far enough to slide it in the farthest back hole.
[This message has been edited by buddycraigg (edited 11-19-2003).]
I didn’t even bother removing the air duct, I just went over it and it workout fine. Attached the hook on the left torsion rod and pulled it back with the ratcheting tie strap. Removed pin from middle hole and put it in rear hole
The last time I adjusted the spring tension, I some rope and one person with lots of pulling power, and another to insert/remove the pin. :slaps self upside the head:
THANK YOU!! To everyone who answerd I have not gotten out to try anything yet, but I'm sure with all the help I will get it fixed. It is cold, nasty and wet and I do not have any cover!
Should I move both pins? Or can I just try moving one first, check, and if necessary move the other as well?
You can only move one pin at a time. See what it's like, move the other if required.
With a piece of nylon rope attached to a three foot length of 2x4 acting as a lever in the trunk, it's very easy to release enough tension from the pins to allow their change of location.
Well, first attempt didn't go so well. I hooked one end of the tie strap to the left torsion rod and the other end to what I think is the cruise control bracket (my car has no cruise control). It took quite a bit of force to move the rod. It actually took so much force that it completely bend the bracket out of shape. So not sure how to proceed. I could use a 2x4 as a lever, but that requires an extra set of hands and I don't have any help so I need to figure out a way to do this by myself.
Perhaps my arms are longer than yours, but for me it's a one-man job. One hand pushes/tips the 2x4 back, while the other hand relocates the pin(s).
One tip... the end of the 2x4 doesn't go down into the bottom of the trunk. It just sits on the little "shelf" directly behind the forward lip of the trunk.
