  3800NA swap -- Can the oil pan be rotated to make the dipstick easily accessible?
3800NA swap -- Can the oil pan be rotated to make the dipstick easily accessible? by tgs.nl
Started on: 05-23-2020 10:34 AM
Replies: 4 (494 views)
Last post by: Lou6t4gto on 05-24-2020 03:02 PM
tgs.nl
Report this Post05-23-2020 10:34 AM Click Here to See the Profile for tgs.nlSend a Private Message to tgs.nlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure this has been asked and answered a million times and I swear I searched over and over again and couldn't find anything.
Swap was done 15 years ago. Haven't logged on here much since then. The cradle is out and I'm doing a bunch of maintenance. Can the oil pan be rotated 180 degrees putting the dipstick tube is on the side of the engine?
TIA, --Terry
Report this Post05-23-2020 11:34 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I doubt that the dipstick location can be relocated. I don't consider the front firewall location to be all that bad. Most folks only need to check the oil very occasionally. As my Fiero is a fun hobby car, I only check it once a season. If you want a more remote operation; the 3800 engines come with a low oil sensor on the oil pan, if it isn't already, this sensor can be wired in to set a warning light signal for low oil level
[This message has been edited by Dennis LaGrua (edited 05-23-2020).]
tgs.nl
Report this Post05-23-2020 11:56 AM Click Here to See the Profile for tgs.nlSend a Private Message to tgs.nlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the quick reply and you're right; it's not that bad.
Report this Post05-24-2020 12:09 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Short answer is NO.
Lou6t4gto
Report this Post05-24-2020 03:02 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
remove the dipstick TUBE, make a New one out of 5/16" steel fuel line. and make it longer and "position it" to be easier to get at. (over the top and towards the back of the car) use a dipstick that it longer to go with it, just remark the longer dipstick.
