  Shift light turns on when jumping ALDL
Shift light turns on when jumping ALDL by M.aaron80
Started on: 05-22-2020 03:46 PM
Replies: 8 (268 views)
Last post by: Notorio on 06-08-2020 05:28 PM
M.aaron80
Report this Post05-22-2020 03:46 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was trying to read codes That are stored, if any. And when I jump the ALDL the shift light comes on and no check engine light. What can cause this? I have an 86gt 4spd.
fierosound
Total ratings: 286
Report this Post05-22-2020 05:23 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Without jumping ALDL connections and Key On - is Check Engine Light ON?
(asking to make sure CEL bulb is not burned out)
Do you jump ALDL connections, THEN turn Key to ON position?
https://www.fiero.nl/cgi-bin/main.cgi?ECMCodes
M.aaron80
Report this Post05-22-2020 05:27 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check engine light does not come on when the key is on. How would a bad bulb make the shift light come on?
Report this Post05-22-2020 05:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
It may not be a bad bulb....it may be a bad ECM. Replace the bulb to find out.
[This message has been edited by Gall757 (edited 05-22-2020).]
Report this Post05-22-2020 05:36 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That makes reading codes a whole lot more difficult. You need that light to be working. As mentioned, check to see if the bulb has burned out.
Are you absolutely sure you're using the correct terminals, as sometimes the ALDL connector is mounted upside down?
fierosound
Total ratings: 286
Report this Post05-30-2020 10:47 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
So.... did you fix this and get the ALDL Codes?
M.aaron80
Report this Post06-03-2020 11:03 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
No, I can’t find the problem
M.aaron80
Report this Post06-04-2020 11:14 AM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
The problem is my bulb!
Notorio
Report this Post06-08-2020 05:28 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
So with the new bulb are you getting any codes? I was thinking perhaps the CEL was burned out because it was ON all the time ...
