  Modded intake for v6
Modded intake for v6 by M.aaron80
Started on: 05-18-2020 03:11 PM
Replies: 22 (863 views)
Last post by: La fiera on 05-26-2020 09:41 PM
M.aaron80
Report this Post05-18-2020 03:11 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any1 have a modded Intake laying around for a v6? I don’t have the time to make one.
jjd2296
Report this Post05-19-2020 08:06 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I’ve tried asking this same question. Decided just to make it myself. Well not all of it had fab done by a friend.
[This message has been edited by jjd2296 (edited 05-20-2020).]
Habanera Hal
Report this Post05-19-2020 10:07 AM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296: Do you have a thread that shows how you did this, why you did this, and what the measurable results were? Thanks.
jjd2296
Report this Post05-19-2020 01:25 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is a well documented mod done to the PPG cars. It eliminates the runners inside the plenum closes the gaps between them and enlarges the neck right at the choke point. The increased air volume from the mod is significant. With a 3.4 pr swap it will significantly reduce the choke out due to lack of air after 4500 rpm. Yes don’t have specific specs on the improvements but they are out there here on PFF.
Here’s one recent thread.
https://www.fiero.nl/forum/Forum2/HTML/143620.html
[This message has been edited by jjd2296 (edited 05-19-2020).]
lou_dias
Total ratings: 67
Report this Post05-19-2020 01:36 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
The hogging out of the walls between ports at the bottom of the middle intake did more for >4500 rpm power than anything else. ;-)
You can almost keep the entire intake stock and benefit just from that one simple mod. I see you left the EGR port on the intake. Did you at least deepen the neck area to allow more flow volume there? That is a huge restriction overall.
EDIT:
Ah with that latest picture I now see that you did deepen/enlarge the neck area! Nice work!
[This message has been edited by lou_dias (edited 05-19-2020).]
M.aaron80
Report this Post05-19-2020 01:39 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately I don’t have a welder for the fab work. Anyone in the Ohio area I can send my intake to have it modded?
Total ratings: 328
Report this Post05-19-2020 01:40 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
This mod is a good one and will undoubtedly work to improve air flow especially at the high end of the power band. While the peak torque and horsepower will be better you may lose some torque and horsepower at the lower end in the 1000-2800 RPM band.
jjd2296
Report this Post05-19-2020 02:19 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
EDIT:
Yes I’ve done your middle intake mod too!
sourmash
Total ratings: 50
Report this Post05-19-2020 03:04 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you recommend an affordable welder for aluminum intake work like that shown above? I've got a keen interest in learning this skill for the rest of my semi-retirement.
[This message has been edited by sourmash (edited 05-19-2020).]
cvxjet
Report this Post05-19-2020 04:31 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been modifying an 87-88 upper for my 85 w/ 3.4 F-body longblock.....Have it done and installed but need to test it. The 3.4 with L44 induction system would pull 4500 RPM going up hill with a friend and me in (Getrag) 4th gear...Next sunday I am planning on testing it again with the modified manifold....
[This message has been edited by cvxjet (edited 05-19-2020).]
M.aaron80
Report this Post05-20-2020 11:25 AM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can someone sell me a modded a modded Intake then? I’ll give you my stock as a core also.
Notorio
Report this Post05-20-2020 11:03 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
cvxjet, how did you cut the intake? Also, what diameter Aluminum pipe did you use for the piece to weld on? It's nice to see a design like this retaining the EGR for purposes of smog testing.
[This message has been edited by Notorio (edited 05-20-2020).]
cvxjet
Report this Post05-21-2020 01:06 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe it is 2 ID 1/4" wall tubing but I will go check........I used a number of tools to do the cutting- Did some drilling, and also picked up a couple of carbide cutting wheels for my B&D "Dremel" tool.......Simply put, it took time and patience...
cvxjet
Report this Post05-21-2020 12:23 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
cvxjet
Member since May 2010
Notorio, here is some more pics......The tubing was 2" ID/ 1/4" wall and 6" long. Also, when I did get done removing the section out of the manifold, I cut out and saved the PCV nipple, because anything you can find to take it's place will stick out so much it tends to interfere with the fuel rail. I drilled a hole that was tight and then tapped it in with some RTV around it to make sure of a good seal.
[This message has been edited by cvxjet (edited 05-21-2020).]
Notorio
Report this Post05-21-2020 06:33 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's excellent .... thanks! I just wondered if you could offer a simple 'kit' consisting of the pre-cut tubing and a template that can be applied (idiot proof) to the intake to transfer cutting lines? Do you think JB Weld could stand up in place of getting the welding done?? I'd buy a kit like that b/c now one is just dealing with regular tools in the garage and won't destroy the paint by heating. Perhaps all you'd need was a splash of paint and you're good to go.
cvxjet
Report this Post05-21-2020 07:30 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think JB weld would hold up....and I'm kickin' myself for not taking a pic of the pre-welded manifold in place with a ribbon holding it together....would have been hilarious!
I am going to do a whole post on this mod as soon as I test the car next Sunday....Maybe I can do a pattern and place it on graph paper in a pic that can be printed..
I did take it for a drive yesterday and it seemed to be a bit better above 4000 rpm- in 2nd it revved out to 5200 and was still pulling......
jjd2296
Report this Post05-22-2020 06:52 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I’ll be installing mine this weekend. My mod will Have the plenum hold 25% more air capacity than just the neck mod and the air will get to the middle intake runners faster as there no runners Inside the plenum to channel the air. I’ll take some pics and video of before and after.
[This message has been edited by jjd2296 (edited 05-22-2020).]
jjd2296
Report this Post05-23-2020 04:05 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I forgot to take a before video and o still have to take the after video but I can tell you this made a huge difference! Pulls all the way to 5500! Big improvement. I can cruise at 140 in 4th! And pull to 160 easy. The extra air intake and the 3.4 results in great 👍 improvement but it will need a chip burnt to have it run perfect.
lou_dias
Total ratings: 67
Report this Post05-26-2020 09:30 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to hear it!
The stock Fiero programming is overly rich >4100 rpm... What cam did you use? That's probably what's limiting your power >5500...and perhaps your throttle body... Also - I assume you ported the heads...
jjd2296
Report this Post05-26-2020 10:41 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
260h cam but have 1.6 rollers to add at some point. Ported everything. Any suggestions for leaning it a bit? I do have an adjustable fuel pressure reg.
lou_dias
Total ratings: 67
Report this Post05-26-2020 04:17 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't do anything until you get it on a dyno. I would only adjust the fuel pressure if you had an immediate problem that showed up on the dyno, other than that just tune it with TunerPro and a chip burner.
Anyway, it's your cam limiting your power as far as the rpm goes...
Is this the cam you have?
https://www.compcams.com/hi...207-2-8-3-4l-v6.html
jjd2296
Report this Post05-26-2020 06:19 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
No mine is a custom grind. Little bit more than a 260h I was told. And o didn’t push it more than 5500 rpm it’s a fresh build still. I do have 1.6 rollers which would give me so me more lift
La fiera
Report this Post05-26-2020 09:41 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the advertised duration and duration @ .050 and what LSA is it ground on?
