  Windshield molding question
Windshield molding question by CSM842M4
Started on: 05-14-2020 02:35 PM
Replies: 5 (563 views)
Last post by: Spoon on 05-19-2020 09:18 PM
CSM842M4
Report this Post05-14-2020 02:35 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm getting ready to paint my '86 GT, and in the process of removing parts that don't need painted or will get in the way. The windshield molding is coming out of where it belongs, and would cover part of the A-pillar skin anyway, so it's got to go. The large question is, does the windshield have to come out to get the molding out? If so, is it a glue-in arrangement? Again, my Chilton's manual is less than helpful. Any/all input is greatly appreciated. Thanks in advance -Chris
fierosound
Total ratings: 286
Report this Post05-14-2020 04:12 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take it out. Leave the glass in.
https://www.fierostore.com/...20%20FRONT&d=307&p=1
From Factory Service Manual:
[This message has been edited by fierosound (edited 05-14-2020).]
CSM842M4
Report this Post05-14-2020 05:24 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, fierosound. Yep, the picture looks like straight out of the FSM (thanks, IMSAGT). That sure simplifies things.
wftb
Report this Post05-14-2020 05:29 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
The last windshield I got put in came with new generic moulding, I could not tell the difference.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
Chief08
Report this Post05-15-2020 09:37 AM Click Here to See the Profile for Chief08Send a Private Message to Chief08Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just did this a few days ago. You will need a heat gun and some patience. I used the heat gun to heat up a section at a time, then used a small flat head screwdriver to gently pry up a part of the molding. Once part of the molding was separated, I used a pair of pliers that have a 90 degree bend at tbe end to pull the molding up adding heat along the way. Whatever you do always pry away from the glass and you should be good to go.
Dave
Spoon
Total ratings: 61
Report this Post05-19-2020 09:18 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's an old and interesting link for the newbies.
//www.fiero.nl/forum/A...110502-1-075941.html
Spoon
