  Is there anyone well versed in Fiero wiring?
Is there anyone well versed in Fiero wiring? by TheDuke
Started on: 04-09-2020 03:25 PM
Replies: 2 (146 views)
Last post by: Msaby on 04-09-2020 05:04 PM
TheDuke
Report this Post04-09-2020 03:25 PM Click Here to See the Profile for TheDukeSend a Private Message to TheDukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
i am trying to track a loss of voltage and im not sure how to get any farther than i have. i have 12v coming out of the fuse panel, goes to a connector at the firewall still have 12v goes the fuel pump relay still have 12v but im not sure where it goes after that. coming from the other way at the fuel pump connector i have 8.5v and tracking that all the way thru the car it goes to the dash where i have 8.5v. Can anyone fill in the gap for me?
fierosound
Total ratings: 286
Report this Post04-09-2020 03:35 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is your 3rd thread for same problem.
Please keep everything going in this one...
https://www.fiero.nl/forum/Forum2/HTML/143652.html
[This message has been edited by fierosound (edited 04-09-2020).]
Msaby
Report this Post04-09-2020 05:04 PM Click Here to See the Profile for MsabySend a Private Message to MsabyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you try jumping the 2 pins on the oil pressure switch, turn the key on and see if you have 12 volts at the pump. If you do not have 12 volts at the pump you will need to replace the fuel pump relay.
Just my 2 cents
Mike
