The one for the gauge is by the coil on the V6.
https://www.fierostore.com/Tech/Default.aspx?Id=99If a parts store tries to sell you a sender for the gauge that doesn't have the same connector as the old one, it's not a sender for the gauge.
The pin next to the notch is for the light and normally the Dark Green wire connects to it.
The pin away from the notch is for the gauge and normally the Dark Green/Yellow wire goes to it.
The shell of the connector normally has baked away and fallen off. The wires many times get reversed causing the temp gauge not to work and the temp light to light dimly when the engine gets up to temperature. Reversing them back fixes the problem.
A new shell can be purchased for cheap here -
http://rodneydickman.com/pr...1acf0bc46a6a00b19c5c - It snaps over the existing metal terminals and you are back in business. Put some dielectric in the connector since GM stupidly used a connector that wasn't waterproof in this location.
