  Wiring under front hood
Wiring under front hood by Imnuts
Started on: 03-31-2020 08:22 PM
Replies: 1 (142 views)
Last post by: Imnuts on 04-04-2020 02:58 AM
Imnuts
Report this Post03-31-2020 08:22 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know if there is an already existing Hot in ACCY or Run wire in the front compartment. Trying to install some daytime running lights and it would be much nicer if I did not have to go through the front fire wall or what ever its called.
∇PONTIAC∇
“The difference between a Fiero owner
and a genius is that genius has its limits.”
[This message has been edited by Imnuts (edited 03-31-2020).]
Imnuts
Report this Post04-04-2020 02:58 AM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI
Found that the heater fan relay in front compartment has a wire that becomes hot when ignition switch is on.
There is also a wire that is hot all the time gong to the radiator fan relay.
Installed some new daytime running lights/sequential turn signals using these two wires without running any wire into the dash area.
∇PONTIAC∇
