| quote | Originally posted by Spoon:
Dennis, research this and see if it helps.
[URL=https://www.ebay.com/itm/For-1994-2005-Cadillac-DeVille-Oil-Pump-28626GN-1995-1996-1997-1998-1999-2000/392402065943?hash=item5b5cfc5a17%3Ag%3AVJgAAOSwA%7EpdZdi8%3Asc%3AFedExHomeDelivery%2119320%21US%21-1&fits=Year%3A1994%7CModel%3ADeVille%7CMake%3ACad illac]https://www.ebay.com/itm/Fo...le%7CMake%3ACadillac[/URL] Spoon
Thanks for the lead Charlie, but the item is not described correctly in the ad. That's a Northstar oil pump.
| quote | by Neils88 There are a few rebuild parts available but many of the main parts of the 4.9 have been discontinued. It's a pretty bullet proof engine fortunately. Might have to look at a pick n pull if you have to replace it. |
The pump develops full pressure but when I changed the oil it took a while to come up, like 10-15 seconds with a full oil filter. Although my engine is low mileage 61K I don't think that the owner changed the oil that often. Now on the second oil change since I've had it. On the first change,the old oil was black.. Now on the second change, the oil is clean. The leakdown rate is very low and well within the spec of a low mileage engine. I don't really need to change the pump but always like to err on the side of caution.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 04-01-2020).]
