  Sensor readings
Sensor readings by Monkeybean007
Started on: 03-31-2020 06:57 PM
Replies: 5 (128 views)
Last post by: theogre on 04-01-2020 12:36 AM
Monkeybean007
Report this Post03-31-2020 06:57 PM Click Here to See the Profile for Monkeybean007Send a Private Message to Monkeybean007Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just picked up an aldl cable and winaldl and all I'm trying to find is what each component is supposed to be putting out stock, so I can compare it to what I am getting to see if theres something wrong.
Total ratings: 568
Report this Post03-31-2020 09:08 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Scan Tool Help and Sensors Quick Ref etc.
Monkeybean007
Report this Post03-31-2020 10:54 PM Click Here to See the Profile for Monkeybean007Send a Private Message to Monkeybean007Edit/Delete MessageReply w/QuoteDirect Link to This Post
While that did have some helpful info I wasn't able to find what I was looking for, I am trying to fin things like a good o2 sensor should put out "blank" volts and then I can look at mine and be like oh that definitely isn't right lol.
Total ratings: 568
Report this Post03-31-2020 11:48 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Because O2 volts changes ever second, even faster the that, the thing is hot enough to run. O2 only generates 0 to 1 volt and ECM only cares reading near 1 or 0 volts.
You know when O2 runs when you see closed loop and O2 ready set true/yes in the data stream via scan tool.
You might see just how fast using a O'scope but not using most meters including "pro grade" meters like Fluke 77 and others.
Monkeybean007
Report this Post04-01-2020 12:01 AM Click Here to See the Profile for Monkeybean007Send a Private Message to Monkeybean007Edit/Delete MessageReply w/QuoteDirect Link to This Post
I guess I misunderstood the use of winaldl then as I was trying to use it to potentially see whats going wrong with my car, so what sensors aren't performing the way they're supposed to, ect;
Total ratings: 568
Report this Post04-01-2020 12:36 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
It can but only for some parts covered in cave pages.
Example Scan reports ECT=90-100°F after running engine for over 1 hour is likely something wrong... The Sensor, wires to it, etc. More so w/ old style sensor w/ crap plug it uses. Even parked for hours engine should be ~ weather temp but scan says ECT is much higher or lower then that.
Temp sensors can be double check w/ meter and charts in the cave. Having some kind of thermometer may help too.
