  Code 32 fixed - New EGR control solenoid.
Code 32 fixed - New EGR control solenoid. by phonedawgz
Started on: 03-24-2020 09:01 PM
Replies: 4 (715 views)
Last post by: armouredking on 07-27-2020 11:54 PM
Total ratings: 291
Report this Post03-24-2020 09:01 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am in the process of making a replacement EGR control solenoid that I will offer for sale. The new solenoid will occupy the same physical space as the existing, will have the same electrical and vacuum lines however will look different. The control solenoid will have two diagnostic LEDs to help to troubleshoot if something other than the EGR control solenoid is causing the Code 32.
The cost of the solenoid will be $90 plus shipping.
Also available will be a diagnostic cable with the LEDs and a digital EGR vacuum display to troubleshoot Code 32 problems caused from things other than the EGR control solenoid. This would be a returnable item.
I have this working on a test basis now and should have it available for sale soon.
Shho13
Report this Post03-24-2020 09:50 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is really great news!!! That damn code 32 will finally be easier to troubleshoot
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Total ratings: 291
Report this Post03-24-2020 10:23 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are three main reasons for getting Code 32. Bad control solenoids, bad vacuum lines, and bad EGR valves, depending on how they fail. Your EGR valve could be non-functional and you could not be getting a Code 32. The code 32 only checks the the vacuum lines and control solenoid. It doesn't know if the EGR valve itself has moved.
fierogt28
Report this Post03-26-2020 08:58 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Realistically, if you have Rodneys or TFS vacuum lines and your new EGR solenoid, there should be no code 32 problems.
Plus, every fiero owner should replace their EGR valve with a new AC Delco unit for piece if mind.
I bought Paul Vargyas refurbished EGR solenoid years ago (2010) and have a new EGR valve from 2008,
and Rodneys vacuum lines (2010) and never got a code since then.
Would like to try / buy yours, and as a back-up replacement.
fierogt28
88 GT, Loaded, 5-speed.
[This message has been edited by fierogt28 (edited 07-28-2020).]
armouredking
Report this Post07-27-2020 11:54 PM Click Here to See the Profile for armouredkingSend a Private Message to armouredkingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any updates on this? I know the world sucks right now, but it has been a few months. Trying to get my car passing emission; it just can't make it and the solenoid is definitely bad. Waiting on a refurb one but no idea when it'll be ready and just want my car to be legal to drive again.
