  Shiftlight
Shiftlight by M.aaron80
Started on: 03-24-2020 06:26 PM
Replies: 1 (256 views)
Last post by: Spoon on 03-24-2020 08:10 PM
M.aaron80
Report this Post03-24-2020 06:26 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry I’m advance for these post. I learn as I go. I have a 86 GT. I did a 5spd swap. Was a 4spd car. I went to jump the terminals with a paper clip to read the codes if any. And the check engine light does not come on,however the shift light comes on when I jump the terminals
Spoon
Total ratings: 61
Report this Post03-24-2020 08:10 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trans swap wouldn't cause that to happen. Did you swap the ECM or chip to the 5 speed version? If not the shift light will function as if you still had a 4 speed when you actually have an extra gear to shift. That still wouldn't cause it to come on when checking for codes. Seems like you had this issue before the trans swap.
Pull your console and look at the ECM harness for any splices. You can also pull the dash cluster and look for the same. Something unusual is going on here.
If someone chimes in and suggest swapping the 2 bulbs (shift - Chk Eng) don't fall for it. Or try swapping the 4 spd back in to see if it makes a difference..
Let us know how you make out. Look up the wiring diagram and get a multi-meter.
Spoon
