Cracking for 1 or more minute can quickly Kill the starter, Battery, and the big cables to the battery. GM spec is 30 sec max run time and 2-5 minute minimum cool time between tries to start.
take off air clearer cover, look into the TBI and see if you fuel spray in there.
ECM won't start fuel delivery unless sees signal from ICM/PIM. PIM could be bad, wires between two bad, or ECM is bad.
ECM can "die" from the heat generated by it and No inject feed is one symptom of this issue.
See my Cave,
ECM Heat,
DIS Ignition,
700 TBI, and likely other pages in those sections.
If you pull insulation and car works then ECM is still "dead" and need a new one quick. Save the prom in it to move that to new ECM.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 03-21-2020).]
