Update System
  Rear Ball Joint replacement
Rear Ball Joint replacement by donuteater306
Started on: 03-19-2020 11:44 PM
Replies: 16 (1043 views)
Last post by: donuteater306 on 04-03-2021 11:17 PM
donuteater306
Report this Post03-19-2020 11:44 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone have step by step instructions for replacing the rear ball joints? I replaced them about 9-10 years ago so they're bolted on. I have the new joints and plan to tackle the job on Saturday. I cannot remember how to separate the joint from the spindle.
If I recall, we raised the vehicle and supported it on jack stands. Put the jack under the control arm, unbolted the castle nut and support bolt. Then lowered the control arm. Is this correct?
ltlfrari
Total ratings: 127
Report this Post03-20-2020 08:11 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Once the bolt is out, the stud should just slide out of the lower part of the knuckle when you lower the A arm.
The originals had a small relief cut in the stud part of the joint so that they will not come out unless the bolt is totally removed, don't know about new ones these days.
Maybe hit it with some pb blaster to handle any rust that might cause it to bind.
Dave
www.ltlfrari.com
wftb
Report this Post03-20-2020 09:10 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sometimes you need to pry open the split on the spindle where the bolt tightens on the ball joint stud. A couple of taps with a hammer and a large straight blade screwdriver does the trick.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
Tony Kania
Total ratings: 305
Report this Post03-20-2020 09:47 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pickle fork.
ltlfrari
Total ratings: 127
Report this Post03-20-2020 11:36 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pickle fork.
Shouldn't need it on the rears as they are not tapered.
Dave
www.ltlfrari.com
wftb
Report this Post03-20-2020 01:06 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
True but you get a lot of corrosion and the studs get frozen in place. Sometimes they drop right out but from my experience they need a bit of persuasion usually.
rear SLA suspension
donuteater306
Report this Post03-20-2020 02:01 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
And this is EXACTLY why I posed this question here on PFF. Everyone’s experiences differ, and all of it helps. Thank you, I appreciate your help.
Total ratings: 236
Report this Post03-22-2020 08:54 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
They could come out easily, especially if you've replaced them during your ownership.
Install the new ones with anti-seize on the shank to ensure they come out next time.
donuteater306
Report this Post03-24-2020 10:11 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I quarantined myself in the garage and replaced the right rear ball joint today. In total, it took about 30 minutes. I was a little disappointed tho...the worn joint was a Moog Problem Solver. I thought that the last time I changed them I had used a cheap set of no-name brand parts because at that time, I was still deciding on what I was going to do with the car. I was considering an 88 cradle swap but decided against it.
Anyway, only the right balljoint was worn, and it was REALLY worn. Why would there be such a difference between the two sides?
ltlfrari
Total ratings: 127
Report this Post03-25-2020 07:52 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was the dust cap not put on correctly, letting dirt/grit in which would act like an abrasive.
Dave
www.ltlfrari.com
MarkS
Report this Post03-25-2020 08:05 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
I been trying to do that myself, no luck yet. My job is apparently essential.
donuteater306
Report this Post03-25-2020 08:32 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
donuteater306
Report this Post03-25-2020 08:44 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
donuteater306
Member since Feb 2010
Nothing appeared out of the ordinary. Everything was together and packed with grease. I drive it about 3-5k miles per year, rain or shine. Ball joints are 10 years old so roughly 40k miles on them. I can understand them not being “new” after 40k, just thought it was weird to have such a difference in wear between the two.
MarkS
Report this Post03-25-2020 08:59 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right rear ball joint. From experience, it seems anything on the right side is more susceptible to roar conditions, puddles, pot holes etc (unless you are in those places were they drive on the wrong side of the road ). Noticed this mostly on the brake components.
SemperFi18
Report this Post04-03-2021 08:27 PM Click Here to See the Profile for SemperFi18Send a Private Message to SemperFi18Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know what those brackets that mount with the ball joints are called? During my rebuild process I seem to have misplaced those.. the ones that sit in between the control arm and the knuckle?
SemperFi18
Report this Post04-03-2021 08:28 PM Click Here to See the Profile for SemperFi18Send a Private Message to SemperFi18Edit/Delete MessageReply w/QuoteDirect Link to This Post
SemperFi18
Member since Aug 2016
This oneThis images is larger than 153600 bytes. Click to view.
donuteater306
Report this Post04-03-2021 11:17 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry man, I do NOT know what those are called. You'll prob have to get them from a wrecking yard tho.
