When I did an oil pan gasket removal years back, I put the floor jack under the pan to support the oil pan. Then I removed the front mount and the front mount bracket. I put a 2 x 4 piece of wood under the front harmonic balancer and the cradle lowered the jack a bit and used that to keep the engine raised a bit. Then I took off all the oil pan bolts and the pan came right down. Then I removed the old gasket, cleaned everything, applied two beads of silicone sealant in the corners around the front and rear main bearing caps, installed the new gasket, pan and put back the oil pan bolts. I definitely did not disconnect or lower down the exhaust. .
