Not hard to put an auto in a stick car. Just did one.
1. remove shifter and shift cables.
2. unbolt, remove clutch pedal, and clutch pedal bracket . connect lines for safety switch together. Discard Clutch Master cylinder, save cylinder and lines.
3. remove brake pedal and replace with auto brake pedal. It bolts right in using a shorter bolt Use existing brake pedal bracket
3. replace radiator with one for an automatic so that you'll have a trans cooler. (or use a separate cooler)
4. run trans oil lines from auto trans to trans cooler
5. bolt in auto shifter with cable . Connect BU light switch leads that were there together.
6. rewire start and BU light switches to go through trans selector switch.
7. Attach trans cable to shortened and reversed auto trans lever on 4T65eHD
Those are the basics.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 03-16-2020).]
