  Reverse gear
Reverse gear by M.aaron80
Started on: 03-14-2020 10:01 PM
Replies: 16 (329 views)
Last post by: pmbrunelle on 05-23-2020 11:44 AM
M.aaron80
Report this Post03-14-2020 10:01 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 86 gt 4 sod. I did a getrag 5spd swap. All gears work but reverse.no grinding or weird nosies. I did see the master cylinder has a small leak behind the pedal but clutch pedal still slightly firm. And the rod in the slave cylinder don’t seem to be moving. Could be worn out slave?
wftb
Report this Post03-15-2020 01:17 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have the original 4 speed shifter you need to remove the reverse lockout mechanism from the shifter. If all the gears work without grinding or having to push really hard to go into gear with the engine running you do not have a hydraulic problem.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
[This message has been edited by wftb (edited 03-15-2020).]
Report this Post03-15-2020 01:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...the rod in the slave cylinder don’t seem to be moving.
I don't understand how any gears "work" if the slave isn't moving.
M.aaron80
Report this Post03-15-2020 09:10 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I have the original 4spd. and I have the 5spd floor shifter installed. Yes this is throwing me for a loop about it working
Report this Post03-15-2020 10:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ummm... I think we've got us a communication problem here.
There's no way ANY of the gears are going to shift properly while the engine is running if the slave isn't moving... unless the clutch is somehow stuck disengaged.
M.aaron80
Report this Post03-16-2020 12:16 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
*UPDATE* slave cylinder does seem to be working but the rod inside of it is not fully extending. Maybe this is because the leak in the clutch master cylinder? Also I did not have the rod that came with the with the 5spd slave cylinder so I used the rod from the 4spd slave. Any difference?
wftb
Report this Post03-16-2020 01:35 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
The slave rod on my 86 only moves about 1.25 " roughly. When the hydraulic system developes a leak it usually causes more air ingress than fluid leaking. But the air in the system is what causes the rod to not move very much. Pitting in the slave cylinder bore is what causes most air ingress.
rear SLA suspension
M.aaron80
Report this Post03-16-2020 04:26 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a new clutch master on the way. The rod moves about half inch. Is the 5spd shifting pattern 1 3 5 on top row and 2 4 R for the bottoms row?
Report this Post03-16-2020 07:14 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not nearly enough.
Yes.
[This message has been edited by Patrick (edited 03-16-2020).]
M.aaron80
Report this Post03-18-2020 02:48 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
*UPDATE* if I push the lever for the cable that moves side to side it will go into reverse gear. Clutch master cylinder has been installed. I did buy the slave from Facebook market. The rod inside of it is only moving half inch
Report this Post03-18-2020 03:11 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Travel required at the slave is 1-1/8" minimum.
Does your clutch pedal hit the floor?
There are literally hundreds of threads here re-hashing hydraulic clutch issues. Look into bleeding procedures, bent pedals, etc.
If the 4spd slave rod is shorter (and I don't know that it is), it's possible your slave is reaching the end of its outward travel before the clutch is being disengaged.
[This message has been edited by Patrick (edited 03-18-2020).]
M.aaron80
Report this Post03-18-2020 03:34 PM Click Here to See the Profile for M.aaron80Send a Private Message to M.aaron80Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will check al that out. Also I am using the shifter arm. (With the knob on it) that was from the 4spd shifter. Is this a problem?
Report this Post03-18-2020 03:44 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't think that the shifter arm would make any difference... as long as it has free range of motion.
fierosound
Total ratings: 286
Report this Post05-22-2020 05:58 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
M.aaron80...
Did you get this clutch thing sorted out?
What was the final solution?
[This message has been edited by fierosound (edited 05-22-2020).]
pmbrunelle
Total ratings: 63
Report this Post05-22-2020 11:08 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I banged my head trying to bleed my clutch over and over again to hit this commonly cited number.
I ended up with something like 3/4" of travel on my Muncie's slave. The clutch works great on my car (for now).
[This message has been edited by pmbrunelle (edited 05-22-2020).]
Report this Post05-23-2020 12:05 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
"something like"? I know you've got enough skillz to get a more exact measurement than that.
My experience is that an Isuzu absolutely requires over an inch of slave travel, whereas a 5-spd Getrag requires less. I have no direct experience with a Muncie 4-spd, but I'd wager a lot of money that a half inch of slave travel would not be enough to properly disengage the clutch.
I did buy the slave from Facebook market. The rod inside of it is only moving half inch.
pmbrunelle
Total ratings: 63
Report this Post05-23-2020 11:44 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
My previous Fiero had the Isuzu, and I think your 1" figure makes sense for that.
On my Muncie, I was measuring the slave travel during the bleeding process, and the clutch didn't work right when there was only 1/2" of travel. I'm sure I had a more exact figure when I was doing the bleeding job, but that was a few months ago, so I forgot the details! I figured I'd post my approximate travel (for the Archives, and future responses to people seeking help) here before completely forgetting everything.
