not hard mostly and no real method but...
To get out/in rubber bushing under MC often easier to remove tire well then the bushing.
Remove well is easy but has front brake line attach to it and plastic often breaks. Just used zip ties only tighten enough to support the line.
If plastic break just mounting ears the drill a small hole and zip tie that to the wall mounts.
