  Dew Wipe Install
Dew Wipe Install by Habanera Hal
Started on: 02-13-2020 03:11 PM
Replies: 4 (656 views)
Last post by: theogre on 02-13-2020 09:31 PM
Habanera Hal
Report this Post02-13-2020 03:11 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm finally getting around to installing my new dew wipes. It seems that every thread on the procedure is either referencing a dead link or the pictures that were helping to explain have gone away.
Does anyone have a good link with pics to do this?
Thanks!
ltlfrari
Total ratings: 127
Report this Post02-13-2020 04:18 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I did mine, back in 2009 or so I used jstricker's excellent article from 2006. While the text is still there, the pictures are gone.
Fortunately for you I saved it all and created a pdf of it which can be had from here:
http://ltlfrari.no-ip.com/P...ewWipes/DewWipes.pdf
When I installed mine, I used some small drill screws that I found at Lowe’s marked ‘Truss Washer Lath Self Drill’ 8x1/2. They had a wide and very shallow head.
The original post is here so you can read all the comments as well:
https://www.fiero.nl/forum/Forum2/HTML/070656.html
Cheers!!!
Dave
www.ltlfrari.com
[This message has been edited by ltlfrari (edited 02-13-2020).]
Habanera Hal
Report this Post02-13-2020 05:47 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
THANK YOU SO MUCH!!!!
PFFer's are the best!
seajai
Total ratings: 51
Report this Post02-13-2020 09:15 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is an istructional video I did a few years ago.
https://youtu.be/kiRvvZNDw7Q
Report this Post02-13-2020 09:31 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
When Dew Wipe(s) are bad...
The whole door needs attention because of the huge amount of dirt gets it.
Window Tracks and the rest of the regulator is likely prublems because of dirt, rust and have loose parts and only replace the dew wipes doesn't help much.
See my Cave, Doors etc.
