I've been working on replacing all my brake lines with TFS brake line set. (85 SE)
When I went to thread the rear brake line fitting into the junction next to the reservoir (dont know the name. The block the rear and two front lines feed in to at the bottom and side), the rear line got tight. This was after I threaded in with my finger to get it started, and was confident it was threading right. It got tight right away, and I went just slightly further, but decided I better not, and back it out. It appears like the thread on the fitting was damaged.
Now I'm thinking about my options, but decided i better ask to get the better option. I was thinking I could either use a die to try and clean the thread, but was told it could be a taper type? If so, what is the name of it? I heard NPT, does that sound correct?
I could get a new fitting and a flare tool. If this route, what size fitting would I need? And is there a specific flare tool I should get?
Could I use a bolt to test if the block thread has been damaged? If so, what size? And if the threading is damaged, is there a specific tap to get?
Should I force it and see if it repairs itself? If not, I'd be looking at a new block, and flaring with a new fitting.
Just say screw it and since I'm wanting to sell it anyways, make someone a good deal? Haha.
Thank you.
1987 Fiero GT
1985 Fiero 2M4
