  what year did series 2 3800SC throttle bodies CHANGE ?
what year did series 2 3800SC throttle bodies CHANGE ? by Lou6t4gto
Started on: 01-23-2020 05:10 PM
Replies: 7 (188 views)
Last post by: Lou6t4gto on 01-25-2020 02:45 PM
Lou6t4gto
Report this Post01-23-2020 05:10 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a few 3800 Throttle bodies here from series 2 3800SC engines. the only difference I can SEE, is the size of the HOLE where the MAF goes in. thus mandating a "different" MAF. How do I tell which is which year ? Thank you
jb1
Report this Post01-23-2020 08:51 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
97-98 same
99+ same.
Lou6t4gto
Report this Post01-23-2020 11:43 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
which one has the Bigger Hole for the MAF ? thanks
jb1
Report this Post01-24-2020 02:24 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
97-98 have the smaller hole with the divider built into the TB,
OntarioKev
Report this Post01-24-2020 02:43 AM Click Here to See the Profile for OntarioKevSend a Private Message to OntarioKevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou,
Different tune required for the two different MAF sensors, so you cant mix/match the PCM (tune) with the MAFs from the wrong year without re-programming them.
Lou6t4gto
Report this Post01-24-2020 01:24 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you !
Total ratings: 328
Report this Post01-25-2020 10:47 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The series 3 3800SC engines (04-07) have the MAF in the air inlet tube and not in the TB housing. This may have been a change to accommodate the DBW TB.
[This message has been edited by Dennis LaGrua (edited 01-25-2020).]
Lou6t4gto
Report this Post01-25-2020 02:45 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
what I "have" ARE for series 2 engines. I am not presently working on a series 3. but thank you for that.
