Fuel filter won't matter.
Same filter is used by cars and trucks w/ far bigger engines.
Many Others have different PN because of different fittings to the line but uses same filter.
If fact unless something is major wrong w/ fuel source etc.... Takes Years to Decades to clog this Filter type.
Is not like small filters many add to a engine or have in old carb designs.
Factory installed Filter... inlet left, outlet right.
CLICK FOR FULL SIZE |
ETA---> Flow direction matters. Flow backward then easier to plug and wreck the media. Should have an Arrow etc to show to install right way.
This filter is mostly installed so mounted on the side, IOW horizontally, so a lot of heavy trash sinks and sit on the bottom and light trash floats so won't plug the media. If swap engine install them different then maybe easier to plug.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 01-22-2020).]
