Following thread above and other to fix the Module is a bad move. Read that all and you find he's "fix" module damn near burn the whole car at minimum.
See my Cave,
Gen 2 HL Motor"Rebuilding" Gen2 HL motors have many problems. Almost as bad as Gen1 but many ignore this and others don't listen. Worse believe hype push by others to sell motor parts.
Module Will shut off even if just turn on by you. Module sees motor w/ jamming, End of Travel, crap "Repairs"/"Rebuilding" motor(s) and shut off power in Microseconds.
Beside actual motor problems... jamming/binding the rest of HL lifts and doors makes motors draw more amps and module can shut off 1 or both motors for this too.
So Module is likely doing its job.
Module don't die only in one direction 99+% of time. Rarely the Relay in it might have crap in the contacts.
Can get New Gen2 motors from Cardone and others.
Cardone AZ has Lifetime Warranty. Can get Cheaper on Ebay and others but has X days (30-90) or no warranty.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 01-21-2020).]
