test light to front turn light
Wire anywhere easy to get at to car frame.
Works then not column switch.
Not then that switch or wires to it.
Behind lower dash trim can get at turn wire at big connector to column top.
But check dash and other bulbs because easy to have more bulbs, sockets, etc bad at same time.
For dash socket... they might look ok but metal cracks and/or plastic warps and doesn't make a good connection.
Might help to switch 2 dash lights and see if problem moves.
Instrument panel bulb layout
https://www.fiero.nl/forum/Forum2/HTML/138175.html------------------
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 01-20-2020).]
