Bought this as a project now pulling my hair out It had a rat
Thought i would rebuild Decided against that [img]https://images.fiero.nl/userimages/Nate snotchies/20190510_171105.jpg[/img] Then i started collecting now ive got two non running fiero second fiero has spark gas but no start it will crank just wont start .... please help
Check fuel pressure and flow trying to start. 9 -13 psi Low/no pressure is mostly problems w/ F-pump, TBI and lines. ECM will not "send" fuel signal if has problems seeing ignition working. Module is likely good but wiring or ECM itself is iffy. See my Cave, HE Ignition and Ground "Myth" notes
need Alldatadiy.com etc for 84. Has correct wiring for 84 that's way different then all later years.
Bad news when i told the guy i just wanted the engine he was in agreement the car wasnt road worthy and came way down on the price.... the rat fiero wasnt too bad but had everything i needed
The red one is a 85 i see fuel going spark is good it freaking wont start with starter fluid
85 86 engine etc are mostly same so use 85 or 86 Fiero FSM or use alldata.
84 TBI Distributor and other things have different connector etc too. So If you swap L4 between two then watch/switch those parts.
Alldata has same data in GM FSM covers most of info most would need but not a complete copy of FSM. Get for a year and print everything you need to PDF software printer driver.
Haynes etc helps some but have many issues or problems trying to match their data to a real car because doesn't get data from GM etc.
Run on starter fluid is possible but can still flood the engine. Check plugs are wet right after trying.
You have 1984 4-cylinder with engine harness chewed up. If engine was OK, all it really needed was new engine harness. But you pulled engine for rebuild and decided NOT to do that now?
So you bought a 2nd Fiero. What year, what engine? That doesn't run either with original engine? You say it has gas/spark and cranks but no fire at all?
And you plan to swap in a 3800 S/C sometime in the future? For which car? The 84 has some wiring very different from later years.
------------------ My World of Wheels Winners (Click on links below)
Not much data here to make suggestions so what I would suggest is that the OP invest in a quality scan tool that will help pinpoint the problem(s) A good start would be to first measure the fuel pressure. Some owners stubbornly resist purchasing diagnostic equipment or software but you cannot accomplish much by working in the blind.
To clear post up i have a 84 thats black i dropped the engine for rebuild and thought i went through all this trouble to drop the engine why dont i just upgrade and put a 3800sc in it ... it was at this point i found the harness chewed up .... so i thought no problem i will just replace when i get the new harness .... but then i over paid for a second red 85 non running fiero i see the gas squirting so i automatically assumed hey ive got gas pulled plugs 3 outta four are wet as well as sparking so my next step will be to use fresh gas because who knows how long its been sitting ... filter change and pressure test are close in my future just frustrated because i had to put a new crankshaft pulley and flange on due to the careless mechanic before me that did tighten it down... purchased with sheared off bolts in the flange....
Gotcha.
Let's get that 85 running. Post what happens with fresh fuel and pressure test.
More frustration the fresh gas and fuel treatment added and go to crank dead as a doornail with a brand new napa battery in it .... hooked up a set of jumpers same results .... i didnt do a fuel pressure test due to the fact i see plenty going into the carb ... how is it that lightspeed has one that has 228,000 miles on it and i have 2 with less miles than that put together ... next up new spark plug since i have had new gas and starter fluid and no kaboom im leaning more towards lack of spark i just cant figure it out ... i cant believe such a small engine can have all these hiccups
Shem after reading these posts ive come to the conclusion that fuel pressure isnt quite right ... i see fuel dumping into carburetor but people say it should be i fine mist of fuel .... therefore im going to chase down the electrical side of the relay and oil pressure switch due to the massive drawl on the battery.... which leads me to believe fuel pump not priming ...
The fuel pump doesnt "prime" - it is submerged in fuel in the fuel tank. The presence of fuel at the throttle body (its not a carburator) proves that the fuel pump is working.
You need to check fuel pressure with a fuel pressure gage.
Make sure the plugs are dry and will spark, pull the fuel pump fuse and try to start on starting fluid. If it fires up u have a fuel issue, if it doesnt u have a spark issue. There should be a pretty fine spray coming outta the injector, if its just dumping gas down the tb its not going to fire. U may have a broken injector if its pouring fuel down
Shem im with you ... hoping a clogged injector not a non working injector is there a fuse for this injector because its definitely dumping fuel not sure how this effects the ecm or the ignition but spark is present feeling like it could be flooding the engine idk what to do
