  Lower intake to block seal
Lower intake to block seal by fierofinder
Started on: 01-17-2020 12:34 AM
Replies: 2 (103 views)
Last post by: pmbrunelle on 01-17-2020 07:08 PM
fierofinder
Report this Post01-17-2020 12:34 AM Click Here to See the Profile for fierofinderSend a Private Message to fierofinderEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rtv between the block and the lower intake has been leaking oil and has recently gotten worse. I'm wondering if anyone has tried sealing this even just temporarily without removing everything and redoing it. I was thinking of trying to clean and remove as much old rtv from outside and laying a thick coat of fresh rtv on. Not sure how long it will last but hoping it will at least slow it down til I'm ready to tear it all apart.
Total ratings: 205
Report this Post01-17-2020 06:43 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would pull it apart and fix it.
The intake to head gaskets may also be failing, if thats the case you could lose the engine.
[This message has been edited by olejoedad (edited 01-17-2020).]
pmbrunelle
Total ratings: 62
Report this Post01-17-2020 07:08 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're not concerned about pretty (washing, deburring, and painting everything), you can easily get the top end off and back on again the Fiero V6 in a weekend.
I wouldn't bother with trying the half-baked fix.
You won't even be able to clean the groove right; it will be contaminated with oil, and therefore, the RTV won't stick.
There's also the concern of potentially pushing pieces of RTV down into the valley, then ending up in the sump, sucked by the oil pump, and then blocking an oiling hole somewhere.
