OM shows most of this...
But...
Any damage to the front hooks/tabs on glass and/or the latch can make big headaches. Including will leak in rain etc.
Worse front edge holes have plastic trim and often is missing. When true... can put the hooks in wrong slot and wreck the hooks.
Plus glass may seem light when opening/closing or out of car... Is another story trying to remove or install because of location and load for you holding it w/ arms straight out. Sim problem using a broom vs holding one at end and pointing to a wall.
Plus Roof Glass can get very hot in the sun... Enough to burn you even if the rest of the car just get warm.
So be very careful how you remove and install the glass.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 01-15-2020).]
