  Recommendations for a Stock Front End Suspension on a Low Mileage Car
Recommendations for a Stock Front End Suspension on a Low Mileage Car by USMUCL
Started on: 12-09-2019 12:55 PM
Replies: 30 (667 views)
Last post by: USMUCL on 01-16-2020 08:57 AM
USMUCL
Report this Post12-09-2019 12:55 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 SE V6 4-speed with 11,500 miles.
History:
About a year ago, I more or less finished the bulk of the "refresh" on this car. It had been garaged, but I still needed to tackle some of the havoc Father Time created, including headliner, speakers, tires, brakes, wheel bearings, plugs/wires, fluids, filters, etc. Because the car nose-dived significantly under braking, I also replaced the front shocks. Because that created a height discrepancy with the rear, I then replaced the rear struts. I kept the original springs and had the car aligned. Again, tires are brand new and road-force balanced. Front suspension has been lubed, and I also replaced the steering shock since it was cheap and easy.
Question:
In the spring when I unpack the car, I want to address some uneasiness in the steering wheel at highway speeds. The steering wheel has a small shimmy/wobble to it, and the steering generally feels light and insecure above 60 MPH.
I can see nothing obviously wrong when I get the car up on the lift, but I haven't put much effort into an assessment to this point, and my suspension knowledge is somewhat limited. I don't know if the springs might be playing a part, or if it is probably just a matter of old rubber in the joints.
If you were restoring this car and wanted to make it "factory new," what parts would you look to on the front end first? I don't mind throwing some money at it, but obviously there's a limit. I want to keep everything stock-ish.
Total ratings: 205
Report this Post12-09-2019 01:33 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check preload on the front wheel bearings.
Check for cracking of the OEM rubber suspension bushings, front and rear.
Check tire pressures.
Check alignment.
The steering will be light feeling, it's typical of mid-engine cars to feel a bit 'nervous' (compared to front engined cars) in a straight line at speed.
[This message has been edited by olejoedad (edited 12-09-2019).]
wftb
Report this Post12-09-2019 01:59 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would also add to the list a wheel balancing, that is a major cause of steering wheel shake. Sorry I did not read that you had already done that. But sometimes even new tires will go out of balance. I have had wheel weights fall off and then the steering wheel shakes.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
[This message has been edited by wftb (edited 12-09-2019).]
USMUCL
Report this Post12-09-2019 02:42 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
Alignment is done (twice)
Wheel balance done (twice, with the second time being road force balanced)
Tire pressures are correct per the door sticker.
Preload was done meticulously on the front wheel bearings when I replaced them due to noise. They are lubed with the proper high temp grease and have no undesirable play.
Checking for old and cracked rubber bushings is certainly on the to-do list.
[This message has been edited by USMUCL (edited 12-09-2019).]
cvxjet
Report this Post12-09-2019 03:46 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
You may need to find the "Wright rench to fit that loose nut behind the wheel" like I do......(Sorry, old silly joke)
There is another remote possibility- I actually had a tire that was very slightly out of round, once......It was unnoticeable at anything below 40, but above it got worse; Realigned, re-balanced and then the guy found the tire was out of round!
[This message has been edited by cvxjet (edited 12-09-2019).]
creaky78
Report this Post12-09-2019 07:41 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is the condition of the ball joints and tie rod ends? I would also check for play in the steering rack.
[This message has been edited by creaky78 (edited 12-09-2019).]
Total ratings: 205
Report this Post12-10-2019 07:36 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will 11,700 miles, I seriously doubt that any hard parts are worn out.
Bearings may flatspot from sitting, but doubtful on the ball joints or rod ends.
USMUCL
Report this Post12-10-2019 08:18 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are good considerations.
So, if I'm confident in the tires, tire balancing, wheel bearings, wheel bearing preload, and alignment . . . and the low mileage would likely have not affected "hard parts," then that leaves just the rubber bits, right?
Off the top of your heads, what rubber parts does that entail? Like I said, I'm learning the suspension stuff as I go, so I will take the suggested "parts list" and start searching DIYs . . .
Total ratings: 205
Report this Post12-10-2019 10:51 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Control arm bushings, upper and lower in front, lower in rear.
Rear cradle bushings.
[This message has been edited by olejoedad (edited 12-10-2019).]
USMUCL
Report this Post12-11-2019 08:29 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
A quick search reveals it's the control arm bushings that are a pain, unless you just replace the entire arm?
wftb
Report this Post12-11-2019 10:37 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero Store has rebuilt arms listed. Looks like 1020.00 or so for all six. Big incentive to do it yourself, you could buy a lot of tools for that kind of money. They look nice though, new bushings and ball joints and powder coated too.
rear SLA suspension
USMUCL
Report this Post12-12-2019 08:34 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, guys. Assuming no damage from an accident, do the arms ever go "bad," or just the bushings? Just curious if the need to burn the bushings out is the only reason to replace the entire arm
Anyone think there is much chance having the original springs still is causing any handling issues at highway speed?
Would hate to go through the pain of changing them out for no reason, especially on the rear. Again, the shocks/struts are new AC/Delco.
[This message has been edited by USMUCL (edited 12-12-2019).]
Total ratings: 205
Report this Post12-12-2019 09:07 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless damaged in an accident, i doubt if the springs need replacement at 11,700 miles.....
You might want to replace the upper spring rubbers, but i doubt they are a problem either.
Rubber bushings are vulcanized to the outer sleeves. When replacing with rubber, the sleeves are already on the bushings, its a matter of pressing out the OEM sleeve.
If going to poly, the sleeve is reused, so its easier to burn the rubber out.
creaky78
Report this Post12-12-2019 10:31 AM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
It has been my experience reviving cars that have been stored for a long period that most if not all the rubber bushings are pretty much dried out and hard, even low mileage ones. My '65 Mustang had 26K actual on it when I found it, stored for 28 years. All the rubber bushings were hard as a rock.
USMUCL
Report this Post12-12-2019 11:19 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, "burning out" the old bushings is only necessary if going to poly and not for rubber-to-rubber? The car is obviously not tracked . . . or even driven hard . . . so rubber is all I need.
I appreciate the continued feedback from everyone here.
USMUCL
Report this Post12-16-2019 04:09 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm on the Fiero Store's website. Confirming this is right if I want to replace all the old rubber bushings in the suspension of the car with new RUBBER?
Two pairs of front upper control arm bushings (4 total)
Two pairs of front lower control arm bushings (4 total)
Two pairs of rear lower control arm bushings (4 total)
One pair of cradle bushings (2 total)
One pair of sway bar bushings (2 total)
One pair of sway bar end links (2 total)
Are the quantities correct, and/or did I miss any rubber bushings anywhere?
Total ratings: 568
Report this Post12-16-2019 06:39 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
AZ and others have Moog or equiv and online orders often is cheaper than TFS and RA w/ free shipping.
See my Cave, Suspension Parts and rest of section.
Rubber CA bushing is best for people driving on the street.
If bolts are stuck/frozen Do Not Cut or Heat them. Cut rubber as needed, find seem on inner sleeve, and center punch right next to that to open that seem.
Bolts Nuts and often even the washers when used are often Class 10.9 or harder and right replacements are hard to find and expensive when/if you find.
You need a press kit and make spacers so press kit doesn't damage the arm to press in and out of the parts.
Total ratings: 205
Report this Post12-16-2019 07:16 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are four cradle bushing locations.
The fronts are one piece, the rear are two piece.
All other quantities are correct.
USMUCL
Report this Post12-17-2019 08:58 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ogre,I will certainly research the install through your cave. I agree that Moog from Advance is the way to go, especially with the online coupon codes. But, Moog shows multiple part numbers for the Front/Lower bushings, so I'll have to figure that one out.
Olejoedad, do you have a recommendation where to get the cradle bushings? Fiero Store only shows the fronts, and I can't find either pairs when I search Advance, Autozone, or Rock Auto. By the way, I have already done both transmission mounts because one was making noise, but I didn't do the motor mount. Perhaps I will do that now also.
Total ratings: 205
Report this Post12-17-2019 04:55 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could do the rear cradle bushings in poly, they are available for all four mounting points.
USMUCL
Report this Post12-20-2019 08:34 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I have a Mustang on which I did lots of poly bushings. Was trying to stay rubber here, but we'll see how this plays out.
Total ratings: 205
Report this Post12-20-2019 09:07 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The cradle bushings wont affect ride much, but will help handling.
wftb
Report this Post12-20-2019 09:08 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the cradle bushings, get Rodney's solid aluminum mounts. There is no reason to use rubber or poly there. Tightens up the handling a bit and no increase in ride harshness. Price wise I don't know, I bought my bushings a long time ago from Daryl Morse.
Phirewire
Report this Post12-20-2019 11:02 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
All depends, the car could have been a trailer princess and have alot of tow miles on her which will wear down springs / shocks. I tend to believe anything over time wears regardless though.
I really am suprised nobody has brought up a new Stabilizer. The one on the car may only have 12k on it but I am sure its lost its pressure by now.
Could also check rack mount bushing as an age wear item and less likely but possible the actual rack bushing may have some wear. Maybe the guy liked to sit in the car turn the wheel back and forth and make race car sounds?
Best of Luck.
USMUCL
Report this Post12-24-2019 04:28 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Best of Luck.
Stabilizer strut was replaced already when I did the shocks/struts, given how easy and cheap they are.
USMUCL
Report this Post01-07-2020 07:20 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have ordered the control arm bushings, sway bar bushings, and end link bushings. Gonna hold off on the cradle bushings for now until I can determine what it will take to install - I do not want to have to drop the whole cradle. While I have no doubt that 32 year old cradle bushings might be hurting cornering, I doubt they are contributing to my highway, straight line steering uneasiness/wobble.
But, what about the rubber on the tie rods and ball joints? Are those just dust covers and "grease holders," or would their condition affect driveability also?
Suspension parts really are new for me, so forgive the dumb question. I get that the ball joints and tie rods themselves are likely okay, given the low mileage . . .
[This message has been edited by USMUCL (edited 01-07-2020).]
Total ratings: 205
Report this Post01-07-2020 08:01 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are just boots.
Mid engine cars do feel a bit twitchy or nervous in a straight line, as compared to front engine cars.
USMUCL
Report this Post01-08-2020 04:57 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! On some of the write ups I've seen on this forum, people were taking the time to convert the tie rod and ball joint rubber over to poly, so that had me concerned it was something that would also affect drive ability
hercimer01
Report this Post01-09-2020 12:30 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a low mileage "49K" one owner car and the tires were out of round. Plus she had let her son drive the car and he beat the crap out of it. I had broken rear ball joint with a perfect alignment. Just because its low mileage, you don't know how it was driven.
Z3SpdDmn
Report this Post01-15-2020 05:08 PM Click Here to See the Profile for Z3SpdDmnSend a Private Message to Z3SpdDmnEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just placed a sizeable order with TFS today to take advantage of their 10% off special. My '88 GT only has 22k miles, but it sat still for about 19 years. The front end needed a refresh. I've already changed springs (TFS lowering springs) and dampers (KYB Gas-A-Just front, Koni Red adjustable rears, I'm looking for Koni Red fronts) and 17" wheels/tires.
My front bushings were definitely worn, to the point that there was play in the upper arm! Rob at The Fiero Store was helpful to make sure I had the right parts put together in my order.
Anthony
'88 Fiero GT 5-spd "barn find"
2012 NASA SpecE30 National Champion
#80 BMW M235iR - Pirelli World Challenge TC
Rooster Hall Racing / FCP Euro
USMUCL
Report this Post01-16-2020 08:57 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, big order. Looks like you're more willing to walk away from the "stock" feel/look than I am.
I ended up ordering Moog bushings for the front upper and lower control arms and the rear lower. Plus sway bar and endlink bushings.
Will start there to see if I get the front end feel I want. I would have ordered the cradle mount bushings, but that job looks pretty extensive, so I'll circle back later.
