Take a look at Tire rack- You can just punch in your car and they will show you the tires that fit that are available. At the moment it shows 4 choices ranging from Kumho @
$152 (Close out) up to Firestone @ $389.
(Both those prices are for a SET of tires).....There are simply not much in choices for those sizes....
(Tire sizes explained; 205/55-15>>> The 205 is the total width of the tire in millimeters; (Divide by 25.4 to get inches)....55 is the aspect ratio (Percentage of the width that is the sidewall height (55% of 205 = 113 (4.4" for each sidewall)....and of course, the "15" is the wheel diameter in inches.
205/60-15 = 24.6" diameter
215/60-15 = 25.2" Diameter
205/55-15 = 23.8" Diameter
Not a big fan of "off brands" but in this situation you can't be real choosy......Those Kumhos are a good deal and they actually rate pretty high....You can have Tirerack deliver to a local shop for installation...(I have my friend at Big O do it (And now Big O usually can match Tire racks prices)
Added note; A lot of people try to get that super low sidewall look but A) It will throw off your Speedo, B) It will change your engine RPM (At Freeway speed 3000 rpm vs 2600) and you can easily strip the tire and damage the rim from hitting debris....(If you must have that look, you need to go to a bigger diameter WHEEL, so that the outside diameter of the tire equals your original tire's diameter(And you don't end up with gigantic gaps around the tire/wheel well)) (I went with 16 x 7 wheels and 205/55 and 225/55 tires.....(To see how it looks, do a search for cvxjet's B pillars) (These size tires were very common so they still make a large selection of tires)
[This message has been edited by cvxjet (edited 12-01-2019).]
