TC125c and others Never downshifts 2-1 at WOT because most times your going too fast and would wreck the trans.
Three speed auto often Does downshift 3-2 even at 50-70mph but have "Rules" to do so.
First does TB/TBI/Carb reaches WOT when you floor the pedal? Many Do Not. See my Cave,
Throttle CableLet assume TV cable is working because normal shifting is "OK..." Is TV cable adjusted right? Many cars the answer is no. Do Not try to adjust until you push the button and adjuster moves in/out easy. See my Cave,
AutomaticIf someone replaces TV cable w/ aftermarket "universal" ones... Take to a Trans Shop for proper adjusting because needs gauges to read trans oil pressure at one or more ports on the trans.
Even then may not downshift all the time depending on "programming" of tran's valve body, governor, and in case of 4T__ the vacuum modulator vs. engine load and car speed.
What is often confusing is what many think is a shift up/down is really TCC locking/unlocking.
ECM, Gear and Brake switches controls this.
ECM controls by engine load and car speed.
3rd Gear switch enables only in 3rd gear. (4T__ 4L__ often have a 4th gear switch too.)
Brake switch disable this when pedal is pushed or the pedal or switch have problems.
