| quote | Originally posted by Will:
You can use the " '99 Oldsmobile Shelby" .bin file (I have it if you can't download it from AllData or similar service) in an 0411 LS1 PCM. This computer and .bin combo can be tuned by *ANY* shop that has HP Tuners. This setup only works on '99 and older Northstars. |
Thanks Will, it's been years since i've been in the fiero community and in the last 6 months i picked up an 88 formula 5 speed and a blue 87GT 5 speed. then someone gave me a 99 caddy with a rusted subframe with 90k miles, engine has already been studded and resealed. then i picked up a monte carlo Z34 with 3.4L DOHC engine for $250..... i've been beating around on which engine to put in the formula, and i've always wanted a northstar but knew the tuning was a problem. *IF* the LS1 PCM works then that would definitely be the way to go for me.
other than 0411, do you have a part # for the PCM? and do i need the LS1 harness to modify, or just modify the northstar harness for the LS1 PCM.
matthew
