  Possible coolant leak?
Possible coolant leak? by branger
Started on: 11-04-2019 09:49 PM
Replies: 8 (174 views)
Last post by: theogre on 11-05-2019 09:42 AM
branger
Report this Post11-04-2019 09:49 PM Click Here to See the Profile for brangerSend a Private Message to brangerEdit/Delete MessageReply w/QuoteDirect Link to This Post
My son noticed the odd water drip on his foot (passenger side), not a constant but the odd drip every once in a while. I don’t have air conditioning, but wondering if it’s a possible coolant leak. He reached up under and it appears to be water... will have to take a closer look. Any thoughts?
Report this Post11-04-2019 10:23 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's the heater core. Easy to replace.
Report this Post11-04-2019 11:30 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likely. Wet area should in front of P-side under dash and feel/smell like antifreeze.
Wet anywhere else and doesn't feel/smell w/ coolant...
rain last few days?
Sunroof and other glass can leak.
Sunroof has drains that must work too. If their plugged then water on floor and/or seat.
[This message has been edited by theogre (edited 11-04-2019).]
branger
Report this Post11-05-2019 12:24 AM Click Here to See the Profile for brangerSend a Private Message to brangerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Patrick, I will look into replacing heater core!
branger
Report this Post11-05-2019 12:25 AM Click Here to See the Profile for brangerSend a Private Message to brangerEdit/Delete MessageReply w/QuoteDirect Link to This Post
branger
Member since Oct 2018
Report this Post11-05-2019 01:17 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
A single "thanks" would've sufficed.
branger
Report this Post11-05-2019 08:57 AM Click Here to See the Profile for brangerSend a Private Message to brangerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just watched a YouTube video of a guy replacing heater core, and looked simple enough to do, but in the video it did not address air in the system... once you swap out heater cores how do you get air out of system. I’m not a mechanic. 😄
Report this Post11-05-2019 09:07 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by branger:
once you swap out heater cores how do you get air out of system?
Go for a drive...
Report this Post11-05-2019 09:42 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Gall757:
Go for a drive...
Yup. System will "burp" itself.
Check coolant level in overflow tank next few days driving. Hot/cold cycling will force air out then suck coolant from the can so keep that tank level up.
make sure you have correct rad cap.
See my Cave, Radiator Caps
