  2004 3800SC engine noise !?
2004 3800SC engine noise !? by Lou6t4gto
Started on: 11-04-2019 06:30 PM
Replies: 20 (344 views)
Last post by: DLCLK87GT on 11-13-2019 02:26 PM
Lou6t4gto
Report this Post11-04-2019 06:30 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
3800SC engine,(not mine)- "RUNS" fine. Has 1.9 rockers and Headers so has a non stock idle (but not lumpy). The noise, that sounds almost like a Loud "spark jumping", coming from around #6,( but looked in the dark, no spark). Went over the "entire engine" top to bottom with a "stethescope", (belts off) not a sound ! Not in bottom end, not lifters, not rockers( everything sounds like a sewing machine running). Gets louder when put in gear and not moving. I almost suspect either a leaking Header gasket or a cracked Flywheel. (Trans was replaced about 500 miles ago) The header is almost impossible to get to because of it's location. I really don't want to drop the cradle. Any Ideas ??? Thanks
Report this Post11-04-2019 09:32 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Belts off and the sound goes away?
Lou6t4gto
Report this Post11-04-2019 11:19 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
no, the same
Lou6t4gto
Report this Post11-04-2019 11:26 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Member since May 2008
I said in the post, "Belts off". the "sound"( is the same with the belt off", everything "Inside" the engine is silent (sewing machine), but somewhere there is that noise, not clacking, not knocking (I am familiar with those noises). sounds just like a huge spark jumping.
[This message has been edited by Lou6t4gto (edited 11-04-2019).]
Lou6t4gto
Report this Post11-05-2019 03:58 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
oil pressure is 60psi at an idle hot. anyone have any experience with the zzp 1.9 rockers ? before I pull the cover ( of course it's the one that's hard to get to)
BadNewsBrendan
Report this Post11-05-2019 06:49 PM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it sound like its coming from the trans area since that was just replaced? Fly wheel cover rubbing or just the clutch making noise? Hard to make guesses without knowing where its coming from or hearing what it sounds like.
"America is all about speed, hot nasty bad-ass speed" - Eleanor Roosevelt
Tetanus
1984 3800 II SC Build
Report this Post11-05-2019 06:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start car. Put up on lift. Then use a 3/4" 30" long hose taped to a funnel as your stethoscope. Listen around the bottom area where the transmission joins to the engine (flexplate area). I found that the starter gear on my engine was not fully retracting and hitting against the flexplate. It was a loud ringing noise and on first thought believed it to be a rod bearing but it wasn't. The flexplates on these engines can occasionally fail as well.
[This message has been edited by Dennis LaGrua (edited 11-06-2019).]
BadNewsBrendan
Report this Post11-05-2019 09:21 PM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Assumed it was a manual trans since he said flywheel but he didn't specify what trans so don't know for sure.
Tetanus
Lou6t4gto
Report this Post11-05-2019 11:48 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
further inspection, not trans/ flywheel. Took belts off again, removed all rockers and push rods and checked all, put back together, with no belts, no noise ! put belts on, NOISE, took belts off, STILL NOISE ! the sound seems to be coming from "dead center",but cannot pinpoint it. used both a stethescope, a piece of rubber tube, and a long screwdriver. the only way to describe "the sound" is, if i a lifter collapsed, and the roller is Bouncing on the cam lobe, a metal to metal Tap. does not do it 100% of the time, sometimes will stop for 10 seconds. exhaust is all tightened. going to order new LIFTERS and pray ! LOL
Report this Post11-06-2019 03:20 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was never stated outright... but I'd say from the following comment that it's gotta be an automatic.
Lou6t4gto
Report this Post11-06-2019 12:49 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
4t65e-HD
Lou6t4gto
Report this Post11-09-2019 12:34 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
installed new ls7 lifters, same noise. push rods perfect, 1.9 rockers perfect, 65 psi oil at an idle 75-80 at 1500. is a wrist pin or piston going bad a Normal malady of a 3800 ??? absolutely no exhaust leaks. don't want to scrap the engine for something I cannot find thanks
Report this Post11-09-2019 12:52 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
From what I've read here over the years from members with similar symptoms, I think Dennis might be on the right track.
Lou6t4gto
Report this Post11-12-2019 02:30 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
compression test- zip in #2- all the rest good. rockers, push rods, cam good. because it WAS running a (less than 3.4 pully), I'm thinking the piston is toast
Report this Post11-12-2019 03:25 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
head gasket?
[This message has been edited by Gall757 (edited 11-12-2019).]
Report this Post11-12-2019 03:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
"RUNS" fine...
Lou6t4gto
Report this Post11-12-2019 03:45 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
if it was a head gasket, there would be SOME compression, correct ? nothing(combustion or oil) into the water jacket/radiator. no steam from the tail pipes, losing no coolant., no water in the oil. (runs right at 180 degrees.) just no compression and a rapping noise. should have mentioned, this is IN a 97 GTP, and getting to the rear bank is a REAL hand cutting experience. I've dealt with a bunch of 3800SC in fieros (installed, rebuilt), alot easier in a Fiero than the GTP with headers !
Lou6t4gto
Report this Post11-12-2019 03:58 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
when I said runs fine, I thought it was just a lumpy idle from the 1.9 rockers and 3" exhaust. what I meant was it has 65psi oil at idle and goes to 80 at 1500 (Not in the crank). it is only running on 5 cyl (obviously)
DLCLK87GT
Report this Post11-12-2019 04:40 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before you start tearing it down, get a Endoscope/inspection camera that will attach to your phone, pull the plug and take a peek inside. You can get them for $20 or so off Amazon and have it tomorrow.
Lou6t4gto
Report this Post11-12-2019 05:54 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
got one, never got a chance to use it. I don't Have a cell phone, but my wife does. will those things work on any cell phone ?
DLCLK87GT
Report this Post11-13-2019 02:26 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine plugs into the same micro-USB port that the charger cord plugs into. I think on newer phones they're all the same but it depends on the phone and camera.
