  AGM vs Sealed Lead Acid Batteries
AGM vs Sealed Lead Acid Batteries by longjonsilver
Started on: 11-03-2019 03:40 PM
Replies: 9 (819 views)
Last post by: longjonsilver on 11-04-2019 12:33 PM
longjonsilver
Report this Post11-03-2019 03:40 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i moved my battery under the passenger headlight. i noticed that there was rust forming from the battery acid on my battery box and horn. i need a new battery anyway, and i want one that absolutely won't leak. Do i need to spend for an AGM or is a sealed lead acid battery leakproof?
thanks
jon
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun!
Report this Post11-03-2019 04:08 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
No battery is "Leak Proof" but AGM units are much more leak resistance then any Wet types.
AGM, unlike "Jell Cells," uses same liquid electrolyte as wet but absorbed by "sponges."
They don't make a JCell for automotive use.
⚠️Warning: Leaking battery is often a Symptom and if you don't find the real root cause then a new battery of either type won't last long.
Spoon
Total ratings: 61
Report this Post11-03-2019 07:02 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks
jon
How long did it take for the rust to form? I also moved my battery up front under P-side headlight about a year ago. I built my box out of aluminum so it wouldn't rust and I painted the surrounding body metal in that area with rust-preventive paint. No sign of rust anywhere yet. I'm also keeping an eye on the wire harness in that area for corrosion at the terminals.
Spoon
Report this Post11-03-2019 07:20 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use AGM batteries and they last longer and do not leak. As a matter of fact Optima says its AGM batteries can be mounted upside down, I read Optima's quality (now 100% made n Mexico) has fallen so I'll be checking out other brands of AGM batteries to use next time
longjonsilver
Report this Post11-04-2019 07:15 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what BCI group number batteries do you guys use that are available in AGM? The 84 is speced as a 70 and the rest are 75 BCI group number. Who makes a 75 group number AGM?
Report this Post11-04-2019 07:36 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will never buy another Optima battery.
Larryinkc
Report this Post11-04-2019 08:13 AM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Odyssey makes a Group 75 AGM battery, I have one in my Mera. I have used Odyssey batteries in several cars and motorcycles with excellent results. They all lasted at least 6 years or longer and no leakage. I charge them once a month if the vehicle isn't driven frequently with an Odyssey brand charger.
[This message has been edited by Larryinkc (edited 11-04-2019).]
rlndhill
Report this Post11-04-2019 10:11 AM Click Here to See the Profile for rlndhillSend a Private Message to rlndhillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interstate MTZ-75DT is a great AGM battery with a great warranty.
seq
Report this Post11-04-2019 11:44 AM Click Here to See the Profile for seqSend a Private Message to seqEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm happy with my Optimas Red Tops in both of our Fieros.
Since OP is in NS, it might be worth checking Canadian Tire. We're running their Motomaster AGM battery in my wife's Hyindai Accent, and have been pretty happy with it. Not sure if they make the correct group though (considering you relocated the battery, I'm not sure you're running the same group in the first place).
Seq
1987 Fiero GT : Information | Gallery
NOTE: If you re-host any of my images on PIP, send me the Image URL and link to this post, and I'll update it.
[This message has been edited by seq (edited 11-04-2019).]
longjonsilver
Report this Post11-04-2019 12:33 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have 9 inches and change in my battery box. The original batteries for the duke and V6 85-88 will fit. So will the 84 duke battery, but it has a LOT few CCAs
jon
