often the sockets metal parts are cracked and seem ok but can't get a good connection to the bulb, "board" goes thru or both.
other sockets like for side markers and footlights have same problem or corrosion ate the metal too thin or ate some/all completely.
At junk yards, often can get sockets and good bulbs from nearly any car w/ 194 dash bulbs fairly easy. GM Ford and more uses these things but maybe different color and other minor things.
sometime you can "fix" corroded sockets by flipping bulb wire(s) to use other side of glass.
help when you have inspection today then find replacements later.
If you need more then 2 car bulbs, NAPA and others sell 10 or more per box of a nunber for less money then buying multiple 2 packs.
related note... Many front markers and turn lenses fade color over the years then "illegal" w/ OE white bulb. Just use 194NA etc amber bulb to pass inspection etc in most places.
Many front turn lens are made white or clear to use amber bulbs w/ them so xxxNA xxxA bulbs are easy to get.
