Its not a hard install but first you must determine if the CAT is not clogged (a common problem) If it is you'll need a new CAT to replace it. If you need to retain the stock look for your area (and the case is good), then just hollow out/gut the existing cat with a long lug wrench or tire iron. This saves a lot of money and keeps the bureaucrats happy.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 10-20-2019).]
