  Fiero store sending unit all over inaccurate
Fiero store sending unit all over inaccurate by pontiacfierokid1985
Started on: 10-17-2019 10:00 PM
Replies: 9 (396 views)
Last post by: Tom Slick on 10-29-2019 01:17 PM
pontiacfierokid1985
Report this Post10-17-2019 10:00 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
1986 2.8 gt 4 speed. Ok so bought a pos sending unit from the fiero store about 2 months ago. And damn I regret getting this crap a** part. It is so inaccurate it’s ridiculous. 160 bucks down the drain on something I thought would cure my fuel reading problems. So the problem I’m having is it will read 3/4 when full but slowly creep up to full. Once I start driving it will drop to a half then back up to 3/4. Like wtf is going on I did literally 20 miles of driving today off the trip meter after filling up and now it’s pegged on 1/2 tank when I know it prob only burned a gallon. What is everyone doing to fix this issue since the fiero store is telling me that there is no faults with the part and that they test them before sending them out. Where do I check I’m guessing faulty gauge but when did the sweep for resistance check it worked perfectly fine.
Mike in Sydney
Report this Post10-17-2019 10:44 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the gauge sweeps OK then the problem must be in the sender. Did you check the sweep on the sender? One other thing is that the float on the sender could be binding. As you describe the problem it sounds like something is hanging up and then frees itself.
Mike in Sydney
[This message has been edited by Mike in Sydney (edited 10-17-2019).]
Total ratings: 205
Report this Post10-17-2019 11:29 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have installed a few of these, no problem with them.
Total ratings: 568
Report this Post10-18-2019 02:05 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The gauge or wiring maybe the problem even if sender test good.
Fiero Gauges have a "ballast" resistor and contacts that get dirty loose etc. Dash itself can have crap contacts too.
Wire(s) to tank can have problems.
Worse, All can be constant or intermittent problems.
Note that Sender/Pump ground ends in the cabin and iffy ground don't only causes sender problems but can kill the pump too. Buying a new pump can kill that quick too.
See my Cave, Electric Motors
Spadesluck
Report this Post10-20-2019 07:49 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought that some of these needed massaging because they have a chance of hitting the baffles?
George P Wood
Report this Post10-20-2019 10:54 PM Click Here to See the Profile for George P WoodSend a Private Message to George P WoodEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had mine for 2 years and it works fine, actually very accurate.
Total ratings: 458
Report this Post10-20-2019 11:25 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thread from earlier this year... Fiero Store gas tank sending unit
larafan
Report this Post10-21-2019 12:34 AM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I installed one in my 86 I tested and found it hitting the baffles. I had to tweak the float until all cleared. Ok since.
USMUCL
Report this Post10-22-2019 04:44 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, I bet the float is hitting the baffles.
The Fiero Store unit I bought even had a warning on it to check for clearance and bend the float arm, if needed.
I did need to bend mine. But, I wasn't 100% sure it was fixed until after I hooked up the ohmmeter to the unit and flipped the tank upside down over and over again to ensure it went from 0-90 without hesitation at every possible angle.
Tom Slick
Report this Post10-29-2019 01:17 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the link. I just replaced my sending unit with FS one and it will only show 1/4. I tested it before dropping it in the tank and it was good.
