You can try bleeding but if either the clutch master or slave cylinder are worn, they will not bleed correctly. I would try Rodney Dickman for new parts that work or you can take a chance on Rock Auto. Since your Fiero is 30+ years old I would just replace both and then bleed the system using a Mityvac (vacuum bleeder) . For the trans to shift smoothly, the clutch hydraulic system is very dependent on a proper bleed. If done properly the clutch will release fine
