  Stock 2.8 alternator pivot bolt thread pitch
Stock 2.8 alternator pivot bolt thread pitch by pontiacfierokid1985
Started on: 10-09-2019 02:54 PM
Replies: 3 (255 views)
Last post by: 82-T/A [At Work] on 10-10-2019 10:47 PM
pontiacfierokid1985
Report this Post10-09-2019 02:54 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
Like the title says need to know the pivot/hold down bolt size and thread pitch I have the Rodney dickman idler pulley installed but still getting belt squeal when it rains. I’m looking to put a longer bolt with a nit on the back side so it doesn’t come loose also will apply red lock tight
Total ratings: 202
Report this Post10-09-2019 11:11 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, can't help with that, because my Fiero is 1000+ miles from me, so I can't check.
What I will say though is that there are a number of other factors that can lead to belt squealing...
1 - Glazed alternator and crank pulleys
2 - Excessive load on the alternator
3 - Warped alternator bracket (Rodney sells a fix: http://rodneydickman.com/ca....php?products_id=81)
4 - Worn out alternator belt
How new is the belt that's on there? Is this a car that comes out once in a while, or did you just recently replace it?
You might also want to try a set of underdrive pulleys. I went with Rodney's dead idler pulley and the underdrive pulleys at the same time, and never had squealing ever again.
pontiacfierokid1985
Report this Post10-10-2019 10:10 AM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you read the post it will state that i installed a Rodney idler pulley but it’s all i figured it out m8x1.25 is the thread pitch for the pivot bolt. Installed a longer bolt and lock washer with nut on the back side so it wouldn’t loosen up. Belt is only 2 months old
Total ratings: 202
Report this Post10-10-2019 10:47 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, I think you might have misunderstood me. I saw that you installed the Rodney Dickman idler pulley. But the Rodney Dickman product I was referencing in my link was something different. This is an additional item that goes onto your alternator bracket that reinforces the bracket so that there's no deflection. I've seen on a couple of Fieros that I've bought that this bracket is bent, and the alternator sits at a slight angle, which can cause premature wear and the belt to squeal.
[This message has been edited by 82-T/A [At Work] (edited 10-10-2019).]
