  11-13 Buick regal F40 trans
11-13 Buick regal F40 trans by SecretMoparGuy
Started on: 10-09-2019 01:22 PM
Replies: 4 (483 views)
Last post by: fieroguru on 10-10-2019 11:35 AM
SecretMoparGuy
Report this Post10-09-2019 01:22 PM Click Here to See the Profile for SecretMoparGuySend a Private Message to SecretMoparGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone used this in a Fiero? or does anyone know why it would be any different from one in a G6? I would like to do a 3800 SC six speed build. I'm not sure if Archie still sells the 6-speed kits (guessing no) but I know WCF sells some custom parts and I'm pretty handy with fabrication if needed. Let me know your experience/thoughts.
Total ratings: 236
Report this Post10-09-2019 04:48 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those transmissions will have the Ecotec bellhousing pattern, and would need an adapter plate to mate to a 3800.
The only F40 that will bolt up to the 3800 is from the '06/'07 G6.
Report this Post10-10-2019 01:46 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
As Will said, it will need an adapter plate to work with the 3800. It also has different bolt boss locations on the case for mounts, shifter bracket and a different clutch line connector.
What that means is that most available F40 swap flywheels, mounts, shifter bracket, and clutch line connector will not work...
SecretMoparGuy
Report this Post10-10-2019 09:34 AM Click Here to See the Profile for SecretMoparGuySend a Private Message to SecretMoparGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the responses. I'm looking to get an F40 out of a G6 but I saw ZZPerformance sells reman buick regal F40 and wanted to know if it could be a replacement in the future.
Report this Post10-10-2019 11:35 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
ZZP also sells products for the Ecotec engine family... which the Regal transmission is from.
