  cooling system flush
cooling system flush by kevinl85f
Started on: 10-05-2019 05:38 PM
Replies: 4 (794 views)
Last post by: kevinl85f on 10-07-2019 04:31 PM
kevinl85f
Report this Post10-05-2019 05:38 PM Click Here to See the Profile for kevinl85fSend a Private Message to kevinl85fEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the best way to flush the cooling system 2.8
85 GT. thanks
wgpierce
Report this Post10-06-2019 10:00 PM Click Here to See the Profile for wgpierceSend a Private Message to wgpierceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon
Total ratings: 61
Report this Post10-06-2019 10:14 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool off engine. Pull lower radiator hose and drain into bucket. Remove cap on radiator. Remove thermostat from T-Stat housing on engine. Coolant will flow from engine and radiator to low point at radiator hose you pulled off earlier. Stick garden hose in t-Stat housing and open valve slowly. Water will flow into engine and into radiator then into bucket until discharge is clear.
Refer to your handy Fiero maintenance manual for proper refilling procedures. Hint: Fill from engine first........
PS: I know a bucket won't fit under car so use an appropriate container that will and dispose of spent coolant properly.
Spoon
Total ratings: 200
Report this Post10-06-2019 10:26 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Also a good link with additional information:
http://www.pontiacperforman.../cooling-system.html
kevinl85f
Report this Post10-07-2019 04:31 PM Click Here to See the Profile for kevinl85fSend a Private Message to kevinl85fEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks All, Great info, working on it now.
