  spoiler hardware
spoiler hardware by kevinl85f
Started on: 10-03-2019 07:17 PM
Replies: 4 (447 views)
Last post by: kevinl85f on 11-26-2019 02:41 PM
kevinl85f
Report this Post10-03-2019 07:17 PM Click Here to See the Profile for kevinl85fSend a Private Message to kevinl85fEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where can I find the hardware to bolt the spoiler fin to the posts?
Any suggestions? Thanks, kevin
Total ratings: 154
Report this Post10-03-2019 09:48 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a rubber insert that goes into the spoiler. Called Well Nut. The Au-Ve-Co number I have is 16248 and the size is M5 - 8 Range .035 - .232 in. You will need PanHead screws to fit into the countersink of the wing stand in order to prevent breaking the wingstand. I recommend brass or stainless screws and a little never seize on them in case future removal is needed.
Fastenal sells Well Nuts by various manufacturers. Grainger should also have them. I bought mine at an automotive paint and body supply but I had to wait for them to order them in. Fastenal had them on hand.
I also have a Well Nut number 8832. Range .38 - 3.96 mm. These are larger and I don't believe they're the ones I've used for the spoiler.
vette7584
Report this Post10-07-2019 10:03 AM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
i have what you need, i sent you a pm with my contact info
1987 Trans Am
Report this Post11-24-2019 05:22 PM Click Here to See the Profile for 1987 Trans AmSend a Private Message to 1987 Trans AmEdit/Delete MessageReply w/QuoteDirect Link to This Post
I too am in need of hardware for the spoiler. Both for stand to spoiler and stand to decklid
kevinl85f
Report this Post11-26-2019 02:41 PM Click Here to See the Profile for kevinl85fSend a Private Message to kevinl85fEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used well nuts from vally fastners,
I was forced to oversize the holes in spoiler due
to rusted and siezed connectors.
the post above should provide you a start
to find your fix, good luck and good results
