I keep coming back with more issues... Ok here is where I am now. When I bought my car a few months ago one of the obvious issues were the brakes were very soft. I have not driven the car much due to other issues needing to be tackled such as the suddenly breaking driver side deck lid hinge, a coil issue, several wiring issues including dying batteries from failing oil senders (Friday's request for help). Back story is this car sat for 9 years before I bought it. It did run and drive when I bought it as well.
I finally got to a point that I was ready to tackle the brake issue. I spent the majority of yesterday inspecting brakes and lines. I found no leaks. The pads are all good, they slide properly, nothing obvious wrong. I do notice that the original rear brake line is gone and a not very professionally ran new line has been installed. All of the hoses look new, the MC looks new, pads look like barely worn.
I proceed to use a air powered brake bleeder to pull all of the old fluid through the lines and get the air out. I do 3 corners (1 bleeder broke on right front another issue to tackle once i figure out this conundrum.) I check the brakes and they are still incredibly soft. on the jack stands I put the car in gear and hit the brakes to see how much stopping power I have in the rear. Pedal to the floor it stops idle in gear. let off even a little and it starts turning.
I decide maybe the harbor freight pneumatic bleeder may not be working correctly so I do a gravity bleed. Now I have bled through a complete quart of fluid. I am still getting air out of the lines. So I am thinking there has to be somewhere that there is a leak, I again go through all of the connections and follow all of the lines to inspect for a leak, I find no leaks damp spots etc. Where can all of this air be coming from? I am at a loss. is it possible that it is taking this much since that line had been completely changed and I should just keep bleeding? I read up and found some mention of failed cylinder seals on the calipers could be the cause. I hope not since replacement rear calipers for an 88 isn't exactly cheap or easy to find. In fact the only place I have seen rear calipers for an 88 is the Fiero Store at 125 a piece. A family member said to check the carpet in the car to see if there is weeping from the MC in the car. I have the car at my mothers in her garage so I dont have access to it to check that tonight, I am looking for directions to look once I get there tomorrow.
Also as a side thought I know that I can mount front calipers to the rear for the 88. Other than losing the parking brake is there anything else to worry about like throwing off brake bias? Car is an auto and there are no state inspections here. so other than not having an E-brake this could be a more cost effective repair than 250 for calipers. Also could always later install a hydro e-brake not that I plan to drift in the car though.
Another thought even though it is not cost effective just something I saw. has anyone thought of adapting the
Wilwood P-brake calipers for use in the Fiero?
Thanks,
Chuck
"HICCUPP" 1988 2.8 GT Ocelot SS exhaust
